Rob_SRi Black Supra restoration/build
rob_sri
Wow, really nice build looks great
What a transformation : WOW. ;)
What a bloody difference, looks fantastic, I have seen worse paint on 3 year old cars!! Looking very nice on what is a difficult colour to keep clean.
thanks guys, quite a big difference ! even the mrs noticed :p
still nowhere near perfect in person due to stone chips and what looks like where bird sh*t has been left on the bonnet..
but as good as it can be without paint..it looks so much better!
can you come and polish mine?
Detail UK can: https://www.facebook.com/DetailUK !
They were the ones that did this haha not me!
I think I'd go spoilerless myself with this!
tempting.. I love the spoiler though I think its too iconic and kind of what makes the Supra.. would be a shame to get rid of it!
think the plan is to paint it.. masking the toyota badge and the supra badge so that they stencil onto the boot so the boot is black and you're left with them showing in carbon fibre - something a bit different
  • Replies 382
I agree with the facelifts!!
Maybe doluck front at some stage down the line so will probably stay as it is for a while :)
Poorboys stuff is awesome, I had some black hole glaze before which was mint might have to invest!!
See that barn to the left... That's where it originated from..! Certainly come a long way!!
To
Close up of cam cover
I decided to do something about the awful std speakers in the car and start off with a Bit of pikey sound deadening after reading some posts on talkaudio forums of people getting some good results..
Thought I would try it in the rear speakers
Rear speaker pods before
After..
Tape under fixings..
The reduction in vibration is much better.. I used an iPhone app called 'Bass Hz' which has a frequency tone.
Around 70Hz freq was perfect for finding rattles.. Whilst playing this freq to start with touching the panel would reduce vibrations and the sound would become cleaner.. By the time I had done the sound stayed the same.. No rattles and actually deeper tones when fading from L balance to R balance the difference was noticeable
I've just bought some focal ps165 components to go with my mb quart amp which I had in my old car
So il be making some brackets up like this for them tomorrow and wiring in the amp .. So.. We'll see how that goes!
Why is the door silver?
its just the rear speaker holders mate :) havent done the doors yet thats tomorrow!
-edit-
I've just realised what you mean!!! that last picture is copied from the DIY thread.. just an example of the brackets im going to 'attempt' to make tomorrow !
I used flashing tape on a previous Supra to deaden the doors. Worked a treat!
its worked suprisingly well i think! going to go and get some more from B&Q tomorrow to do the fronts with and layer it up! who needs dynamat! :/
Where did you get the LED rear bulbs from mate?
http://www.ebay.co.uk/itm/2x-XENON-PURE-WHITE-5-SMD-LED-SIDELIGHT-INTERIOR-BULB-T10-W5W-501-6000K-6K-/251231914595?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a7e96ca63
as with just about any bulb imaginable if you find the code ie: 501, h11, 233 or whatever then type LED after it in ebay about 50,000 results come up! these are also the same ones for your sidelights :)
and these are for your centre light if you are interested in doing that too :
http://www.ebay.co.uk/itm/290679263260?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Edited by rob_sri (see edit history)
Headed down to the custard factory at the weekend with a few friends. Joined a few guys from the Ford ST owners club ST-OC.com down there too
heres a few quick 'arty' shots :)
https://scontent-b.xx.fbcdn.net/hphotos-prn2/q80/s720x720/1379640_10151784864964864_285286693_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-frc3/q81/s720x720/1378580_10151784864984864_1694770139_n.jpg
https://scontent-a.xx.fbcdn.net/hphotos-prn2/q84/s720x720/1385011_10151784864709864_1853351404_n.jpg
https://scontent-a.xx.fbcdn.net/hphotos-frc1/q75/s720x720/526956_10151784864019864_1688863433_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-ash3/q77/s720x720/1379612_10151784863489864_616999615_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash3/q83/s720x720/9412_10151784863929864_548254258_n.jpg
MDF rings, wiring kit and the components should hopefully turn up tomorrow so I can have a go at fitting it all :)
Loving your work :) Facelift lights and indicators and your car will look even better, they make such a difference especially on a black car
cheers mate !
i agree 100% they are very high up the list! Especially the front indicators!
The 'sound proofing' in the rear has worked so well I'm sure rich will back me up on this!
The difference is unreal and that's with only the back done and some shit speakers!
Even the mrs noticed!
My attempt at some brackets
The new speakers :) the mdf rings are glued and curing in the garage at the moment
Will have a go at fitting them along with my old amp and sound proofing the front at the weekend. Also if I can get someone to give me a hand I can test fit the carbon boot :D
what i've done doesnt really reduce noise more reduce vibrations and improve mid and bass.. its taken some of the tinny-ness from the doors much like if you put your finger on a ringing tuning fork.. and stopped some of the plastics vibrating together.
if you want to reduce volume all together you'd probably have to use proper dynamat or equivalent stuff which you can get in big sheets and put it under the rear seats etc as that seems to be quite thin metal, under the carpets and inside all the panels.. would be awesome when its done.
i've heard of some people using expanding foam etc too to deaden things *be very careful with this * as it can buckle panels if too much is used.. talkaudio forums are a good place to look for ideas and DIYs
hope that helps :)
hope that helps :)
Thanks is fantastic, thanks for the tips, I am going to dynamat the whole of the rear & see how that goes first.
Good choice of speakers dude, should be an awesome setup ;)
