teddan Posted July 30, 2013 Share Posted July 30, 2013 my big AN hose from the tank to engine smells a little bit of fuel if you smell direct on the hose(without pressure). No leakage, even in 50 psi. seems strange? Quote Link to comment Share on other sites More sharing options...
hodge Posted July 30, 2013 Share Posted July 30, 2013 Are you using rubber or Teflon lines? Quote Link to comment Share on other sites More sharing options...
teddan Posted July 30, 2013 Author Share Posted July 30, 2013 no ide mate. It was fitted before I bought the car. Maybe it is just normal rubber hoses with steel braid? Maybe I should buy this instead? "This stainless steel braided hose consists of a teflon (American Dupont) extruded core with a heavy duty, protective, full stainless steel (grade 304) braid on the outside, making it exceptionally lightweight, flexible and durable. Even better, the hose is designed to handle any fuel (including methanol, E85 and nitromethane), oil, coolant, brake, transmission, powersteering fluids and nitrous oxide. The Telfon PTFE core makes this hose significantly more durable and longer lasting than standard rubber nitrile stainless steel braided hose. This hos can be used without hose fittings and secured over 15mm (max) barbed fuel filter/pump OE solid fuel lines with the use of hose finishers / jubilee clips. Temperature range from -73 degree C to +232 degree C." Quote Link to comment Share on other sites More sharing options...
Lee P Posted July 30, 2013 Share Posted July 30, 2013 Teflon hose is better and will not give off vapour like the usual braided line. Its alot stiffer though so can be tricky to run and the fittings can be a bit more pricey. Deffinatly worth it though. Quote Link to comment Share on other sites More sharing options...
teddan Posted August 1, 2013 Author Share Posted August 1, 2013 Thanks lee! then I need top buy new fittings ...darkness... Quote Link to comment Share on other sites More sharing options...
teddan Posted August 1, 2013 Author Share Posted August 1, 2013 Can you recommend a internet shop that have alot of teflon fittings? I have tried sweden but no one have all the fittings I need... Is is possible to fit fittings to aluminium pipe for without welding? I try to avoid a lot of hoses... Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 1, 2013 Share Posted August 1, 2013 Can you recommend a internet shop that have alot of teflon fittings? I have tried sweden but no one have all the fittings I need... Is is possible to fit fittings to aluminium pipe for without welding? I try to avoid a lot of hoses... I can supply Goodridge if needed. Quote Link to comment Share on other sites More sharing options...
Clausz Posted August 2, 2013 Share Posted August 2, 2013 I have bought almost all my fittings from Alex : http://stores.ebay.co.uk/Torques-U-K Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 2, 2013 Share Posted August 2, 2013 Rubber lined braided fuel hose will smell a bit, due to osmosis through the cell structure of the rubber. As LeeP says, if you can manage the restricted bend radii Teflon lined hose is better if the smell bugs you, or frightens your passengers. Quote Link to comment Share on other sites More sharing options...
marc_p Posted August 2, 2013 Share Posted August 2, 2013 or frightens your passengers. I have a slightly leaky oil pressure sensor in the 944 which gives a whiff of oil if you put your foot down and the other day when I had a passenger in the car, I also had a bottle of water, so when they asked about the smell, I chucked them the bottle of water and said 'oh, it's leaking oil and might set on fire, if it does use this', their facial expression was priceless Quote Link to comment Share on other sites More sharing options...
Clausz Posted August 2, 2013 Share Posted August 2, 2013 I have a slightly leaky oil pressure sensor in the 944 which gives a whiff of oil if you put your foot down and the other day when I had a passenger in the car, I also had a bottle of water, so when they asked about the smell, I chucked them the bottle of water and said 'oh, it's leaking oil and might set on fire, if it does use this', their facial expression was priceless I normaly just: Quote Link to comment Share on other sites More sharing options...
teddan Posted August 2, 2013 Author Share Posted August 2, 2013 (edited) Rubber lined braided fuel hose will smell a bit, due to osmosis through the cell structure of the rubber. As LeeP says, if you can manage the restricted bend radii Teflon lined hose is better if the smell bugs you, or frightens your passengers. How dangeruos is it for fire? From my point of view very small chance that this can ignition? Edited August 2, 2013 by teddan (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 2, 2013 Share Posted August 2, 2013 I am still here and my Skyline smells like a petroleum refinery inside, and I smoke..... Quote Link to comment Share on other sites More sharing options...
teddan Posted August 2, 2013 Author Share Posted August 2, 2013 Haha great answer!!! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 2, 2013 Share Posted August 2, 2013 No, seriously,unless the fumes are such they give you a headache it should be OK, that's the downside with rubber lined braided hoses used for fuel lines. I believe some of the very latest liner materials do not suffer osmosis, but they are probably specialised and expensive. Teflon lined is best, but a pain if you need to get it round tight bends. This is one of the reasons you will find very little length of rubber in stock fuel lines. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 2, 2013 Share Posted August 2, 2013 i am still here and my skyline smells like a petroleum refinery inside, and i smoke..... Quote Link to comment Share on other sites More sharing options...
teddan Posted August 3, 2013 Author Share Posted August 3, 2013 I will smell it if the car are in the garage. But if i let the doors open for a couple of minutes then the smell are gone. If the car are place Outside there are no smell Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 3, 2013 Share Posted August 3, 2013 That's pretty much normal. Quote Link to comment Share on other sites More sharing options...
hodge Posted August 3, 2013 Share Posted August 3, 2013 Can you recommend a internet shop that have alot of teflon fittings? I have tried sweden but no one have all the fittings I need... Is is possible to fit fittings to aluminium pipe for without welding? I try to avoid a lot of hoses... I'd reccomend have Teflon lines made up with crimped fitting. My entire setup is done that way, and I NEVER have any fuel smell inside the car. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 3, 2013 Share Posted August 3, 2013 I use http://www.speedflow.co.uk a lot. Faye there knows her stuff and is very helpful. She also drag races some very interesting cars. Quote Link to comment Share on other sites More sharing options...
teddan Posted December 30, 2013 Author Share Posted December 30, 2013 Willl the same problem occur when I swith to e85(ethanol)? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 30, 2013 Share Posted December 30, 2013 It'll probably be worse. You need Teflon lined hose if the small is objectionable. Quote Link to comment Share on other sites More sharing options...
teddan Posted December 30, 2013 Author Share Posted December 30, 2013 OK, I will change then Quote Link to comment Share on other sites More sharing options...
