Spark Plugs
Sharpie
I have used the search button both here and on MKIV.com but, just want to make sure that I get the right ones.
(I have UK TT running with a little more boost than stock)
I have read: http://www.mkiv.com/faq/faqtt.html#enginefeatures1
and wanted to know if you agree with the comments re: 1095/3330 - BCPR7ES, on this side of the pond ?
and if I understand correctly, the NGK (1283) BKR7E-11: B would be the best choice if I can get them ?????
Oh, any reason to go 2 grades colder ??? or is this too cold ?
Thanks
HKS plugs are Denso's rebadged.
Denso IK22's and IK24's should work fine. 24 is about an 8 on the grading I believe. Possibly too cold.
HKS have S40i's and S45i's which are basically the same just more expensive.
NGK's have to be changed every other oil change as they have a "normal" construction which doesn't last as long as the iridium's under high boost conditions. but they cost a damn site less.
I have recently put in the BKR7E and was misfiring at a little over 1 bar.
I gapped them down to 0.7mm and that mostly sorted it.
It did still miss on me once though.
Can I gap slightly lower ? What are the negative effects ?
The car is runnig nice and idling smooth.
I asked NGK but they didn't really answer and just said fit some BKR7EVX (?), I think platinum tip or something.
Cheers,
Guest Martin F
You can try gapping them down further, but reducing the spark plug gap can sometimes mask the true problem. Which tends to be failing coil packs.
Unfortunately failing coil packs are not easy to test, the best way is by substitution but you obviously need to find a friendly Supra owner with A1 coil packs to save on splashing out.
Originally posted by B1SEP
HKS S40i's , grade 8 , are £14.50+v each and
work an absolute treat , pre-gapped at .85,
last 20k miles+ and should take 1.5bar+
have used them in all my jap cars and very happy
with the results !
So a Denso IK24 at a 40%+ mark up then!!!
Guest Terry S
Originally posted by Alex Holdroyd
Does that make the S45i a grade 9 which would suggest there is an IK26....????
That would be the logical step but I think 9's are OTT TBH. Never looked past IK24's.
