AC condenser fitting ?
peter richards
I can't see it being too difficult Pete, although naturally you'll want to make your system is totally empty before you undo any joints.
Just new gaskets and o rings I'd guess would be good advice, and once the front bumper is out of the way, should be fairly straight forward
It looks like the cooling rad and viscous fan will need removing, to get to the condenser brackets, so budget in a coolant top up/bleed.
I too found a place in the USA for new ones, but fear it could arrive in poor shape, and import duty might make it become expensive.
ill put it in the hands of the garage that found the fault , hes not happy with me finding a second hand one , but im not made of money atm , and it was working ok in the car it came out of , probably going to be a few hundred to fit it , hes estimated 4+ hours , and that's if everything goes ok
