fruity_south Posted July 27, 2013 Share Posted July 27, 2013 Hi guys, hope someone can fill me in on this. Basically I am missin a diff mount (single bolt) which a friend of mine discovered. Now I ordered the alloy ones from eBay but the one that's missing seems to small. Am I missing something else? The other standard one (two bolts looks like there's something else other then the mount like a metal ring. Pics here if that helps Link to comment Share on other sites More sharing options...
Justin Bieber Posted July 27, 2013 Share Posted July 27, 2013 N/A's only came with the one mount you have, so its not missing as such. You can order the second diff mount from toyota, its about £30 if i remember rightly, I have the part number kicking about somewhere I'll see if I can find it Link to comment Share on other sites More sharing options...
markssupra Posted July 27, 2013 Share Posted July 27, 2013 It looks like the whole bush is missing from the right hand mount including the outer steel ring the rubber is bonded to. How did you lose a diff mount? My complete rear suspension is off the car at the mo and here are some pics. Hope it helps. Link to comment Share on other sites More sharing options...
markssupra Posted July 27, 2013 Share Posted July 27, 2013 N/A's only came with the one mount you have, so its not missing as such. You can order the second diff mount from toyota, its about £30 if i remember rightly, I have the part number kicking about somewhere I'll see if I can find it That explains it then, as it just cant fall out Link to comment Share on other sites More sharing options...
fruity_south Posted July 27, 2013 Author Share Posted July 27, 2013 Yes very helpful thank you, if I order one from Toyota will it come with the addition steel ring you mention I am missing. Link to comment Share on other sites More sharing options...
markssupra Posted July 27, 2013 Share Posted July 27, 2013 These are the part numbers off toyodiy.com for my car not sure if different on yours. 1993 TOYOTA SUPRA (JZA80-AJPZZ) GZ JPN AET 2JZGTE TWT ATM 4FC I would think its a complete rubber bush including the inner and outer steel rings the rubber centre is bonded to. 41110S BOLT, NO.2 (FOR REAR DIFFERENTIAL CARRIER SET) 90110-14003 1 $4.19 41651A CUSHION, REAR DIFFERENTIAL MOUNT, NO.2 41651-14020 1 $117.78 Link to comment Share on other sites More sharing options...
Justin Bieber Posted July 27, 2013 Share Posted July 27, 2013 That's the one from Toyota, the part number is 41651-14020 as Mark said, I didn't think it cost that much though! Give Steve Manley at Oxford Toyota a ring and see what he can do for you Link to comment Share on other sites More sharing options...
fruity_south Posted July 27, 2013 Author Share Posted July 27, 2013 Thanks guys. Very strange, makes me wonder if the mounts I bought are supposed to sit over the rubber ones. Link to comment Share on other sites More sharing options...
2soops Posted July 27, 2013 Share Posted July 27, 2013 I've just changed both of these in mine after having the subframe shot blasted and powder coated. PITA to get in as they are a press fit and extremely tight Link to comment Share on other sites More sharing options...
Justin Bieber Posted July 27, 2013 Share Posted July 27, 2013 I've just changed both of these in mine after having the subframe shot blasted and powder coated. PITA to get in as they are a press fit and extremely tight Yeah Chris Wilson recommends removing the subframe and using a hydraulic press to fit these properly, I haven't actually tried to fit mine yet! Link to comment Share on other sites More sharing options...
Nic Posted July 27, 2013 Share Posted July 27, 2013 These are the part numbers off toyodiy.com for my car not sure if different on yours. 1993 TOYOTA SUPRA (JZA80-AJPZZ) GZ JPN AET 2JZGTE TWT ATM 4FC I would think its a complete rubber bush including the inner and outer steel rings the rubber centre is bonded to. 41110S BOLT, NO.2 (FOR REAR DIFFERENTIAL CARRIER SET) 90110-14003 1 $4.19 41651A CUSHION, REAR DIFFERENTIAL MOUNT, NO.2 41651-14020 1 $117.78 These numbers are correct, the mounts are the same on all Supra models, but as said some models only came factory fitted with a single mount. http://img547.imageshack.us/img547/5831/wh1d.jpg Link to comment Share on other sites More sharing options...
fruity_south Posted July 27, 2013 Author Share Posted July 27, 2013 Cheers. I. Still wondering if these are suppose to sit over the rubber ones though as if you are saying that there is a metal ring that runs round the edge of them then on removing the old ones the space is going to be to big for me to fit these. I think this is a job for when I have a weekend clear! Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 27, 2013 Share Posted July 27, 2013 Link to the ebay mounts? They look pretty, but are you sure they aren't supposed to be welded in place? I've just fitted a genuine mount to my NA subframe, it can be done with removing the subframe, or the use of a big hammer (which is not recommended), but my method does involve removing the fuel tank and a fairly meaty example of a bearing puller. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 28, 2013 Share Posted July 28, 2013 Hi guys, hope someone can fill me in on this. Basically I am missin a diff mount (single bolt) which a friend of mine discovered. Now I ordered the alloy ones from eBay but the one that's missing seems to small. Am I missing something else? The other standard one (two bolts looks like there's something else other then the mount like a metal ring. Pics here if that helps [ATTACH]172940[/ATTACH] [ATTACH]172941[/ATTACH] Those things you bought off Ebay are probably a cheap way of effectively making the stock rubber bushes solid, by locking them up by clamping force. You MUST NOT, NOT *NOT* fit them unless the front mounts on the diff are also solid. I would just buy the "missing" bush from Toyota and fit it the correct way up, as per the shop manual, and leave it be. Link to comment Share on other sites More sharing options...
fruity_south Posted July 29, 2013 Author Share Posted July 29, 2013 Yep your right, there not how it is advertised. The seller confirmed these sit over the rubber ones. I have also the front diff ones so can still fit them just need to get the extra rubber one first from Toyota if I want to do all three Link to comment Share on other sites More sharing options...
