Oil leak. Please help identify it with the pics
SupraLEDrears
I can't quite tell from the pictures but are your cam cover seals weeping oil which is then dripping down and filling that hole as well as onto the bell housing? If so, try checking the cam covers are actually tight as the bolts work loose or better still replace the cam cover seals.
Yeah the cam covers always leak. Mine have leaked down the back of the block and into the bellhousing giving me a scare something was more seriously wrong. But after a bit of investigation it was just the cam cover seals.
Don't over tighten them though. They are low torque for a reason. You can easily crack the cam covers.
