drift_bear Posted December 8, 2013 Share Posted December 8, 2013 If it runs on easy start or brake cleaner - you know its a fuel related issue. Will try that tomorrow chris and also order up a new HT lead from the coil to distributer from mr T aswell so we can rule out that as a cause! Quote Link to comment Share on other sites More sharing options...
Benjy Posted December 9, 2013 Share Posted December 9, 2013 Try making it run on sniff first bud. My money's on fuel pump/relay. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 9, 2013 Share Posted December 9, 2013 Try making it run on sniff first bud. My money's on fuel pump/relay. The fuel pump is working fine mate Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 9, 2013 Share Posted December 9, 2013 It's either igniter, disi pickup coil, or wiring issue between the igniter / disi / ecu.. After messing with no spark engines you often need to sand blast or renew the plugs to get them to start, after the no spark issue is corrected. Reading the correct pages in the workshop manual would make diagnosis a lot easier for you.... Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 9, 2013 Share Posted December 9, 2013 It's either igniter, disi pickup coil, or wiring issue between the igniter / disi / ecu.. After messing with no spark engines you often need to sand blast or renew the plugs to get them to start, after the no spark issue is corrected. Reading the correct pages in the workshop manual would make diagnosis a lot easier for you.... There's already a new dizzy, igniter, coilpack and plugs in chris. Going to try new ht leads and if that doesn't work, then it's off to a car electrician to get wiring checked Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 9, 2013 Share Posted December 9, 2013 It won't be the HT leads unless the king lead (disi to coil) is *W I D E* open which can check in 3 seconds with a cheap multimeter. Needs a scope on the disi trigger coil, then on the igniter, then on the coil trigger side. To be honest many of these none start issues could be identified by a decent garage in next to no time. Factor in your time (which you MUST do, unless you have rewritten the economics books) and swapping stuff out ad hoc is more costly than paying a pro. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 9, 2013 Share Posted December 9, 2013 It won't be the HT leads unless the king lead (disi to coil) is *W I D E* open which can check in 3 seconds with a cheap multimeter. Needs a scope on the disi trigger coil, then on the igniter, then on the coil trigger side. To be honest many of these none start issues could be identified by a decent garage in next to no time. Factor in your time (which you MUST do, unless you have rewritten the economics books) and swapping stuff out ad hoc is more costly than paying a pro. It's still throwing up a code 12, so it's been booked into a car electrician to get the wiring checked. There's no such thing as a decent garage up this way that I would trust on a supra tbh, that's why we do it ourselfs Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 9, 2013 Share Posted December 9, 2013 Bloody `ell, and you want independence? If I couldn't find why there was no spark in half an hour I'd offer to go dry over Christmas.... No race car places that do Motec or other high end ECU installs.? Should be simple for such a gaff to sort it. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 9, 2013 Share Posted December 9, 2013 Bloody `ell, and you want independence? If I couldn't find why there was no spark in half an hour I'd offer to go dry over Christmas.... No race car places that do Motec or other high end ECU installs.? Should be simple for such a gaff to sort it. No mate, AFAIK there's one place that "does" that, but they couldn't store a base map onto an apexi ecu! Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 9, 2013 Share Posted December 9, 2013 Tried some easy start like suggested and still nothing at all, just the usual cranking and nothing... Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 9, 2013 Share Posted December 9, 2013 It's still throwing up a code 12, so it's been booked into a car electrician to get the wiring checked. There's no such thing as a decent garage up this way that I would trust on a supra tbh, that's why we do it ourselfs Very true. I could not find a good reputable garage anywhere in Scotland. Thars why I DIY Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 9, 2013 Share Posted December 9, 2013 Very true. I could not find a good reputable garage anywhere in Scotland. Thars why I DIY That's why we're trying everything before resorting putting it into a car electrician to check all the wiring I don't mind getting my hands dirty but when it comes to electronics i don't touch lol Quote Link to comment Share on other sites More sharing options...
Gymshoe Posted December 23, 2013 Share Posted December 23, 2013 Woohoo problem finally solved now time to enjoy it! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 23, 2013 Share Posted December 23, 2013 Going to share this with us? My bet is, it was the disi, (reluctor coil issues).... ??? Quote Link to comment Share on other sites More sharing options...
Gymshoe Posted December 23, 2013 Share Posted December 23, 2013 Going to share this with us? My bet is, it was the disi, (reluctor coil issues).... ??? Had to put in another new distributor cause the one i first got had cracks on the metal shaft that goes into the engine, so replaced that it still wouldn't run! Luckily drift_bear bought a spare ecu just incase, so put that in and boom she turned over perfect! Quote Link to comment Share on other sites More sharing options...
