Starting and running problems (renamed)
Guest zeeok
Dude go try the igniter on the car. I put money on it that's the problem. Had it on my first supra. Same symptoms gets hot and breaks down once cooled down it behaves again.
The car hasn't ran since Monday so will be cooled down, still not starting before we changed the distributor
  • Replies 64
Well spark is one area to check. So check water on plug wells. This can be very intermittent to constant.
The check for fuel.
Remove the battery for a while or main fuse, google which, that will remove codes and u can go again. But water in the Clark chamber brought me 3 faults entirely unrelated to the water. Cleaned it out and everything went away!
The check for fuel.
I know to disconnect the battery and that will erase all the codes so I can then recheck. Cause we can't get the car to my house I'm doing this in the street between snow showers :( it's going to be a long day
Code 12 is the Crankshaft position sensor. When this goes wrong you'll have starting and running problems ;)
A lot of the problems in this area in the past has not been due to the sensor itself, but the sprocket it reads coming free from the crank.
I asked keron a few weeks back for a crankshaft position sensor and he said the NA's didn't have one :think: where about is it located ian? Am I able to fix/clean it or do I need a new one?
After getting the issue about crankshaft position sensor on an NA sorted, I went back and checked over all the connections, timing and plugs. Everything seemed to be ok until I noticed the plug on the side of the distributor wasn't on proper, quick push together and I'm getting some progress!
Now instead of the engine just cranking and nothing happening, it's now cranking and trying to turn over fully but not quite making it! I took of the oil cap and there was a little smell of fuel in it. This would of been caused by the excessive turning over/cranking the last few days by my mate and a couple of times today by me.
Tonight once my mate gets home from work, we're going to check how healthy the battery is and put in some more fuel (it's currently on the last line before empty). Anymore ideas on what to check?
Make sure the pump's pumping dude. And also when it does run, have a sniff at the back of the car. If it smells mega fuelly it could be a ECT sensor flooding it up. Spray a bit of easy start up the air intake and if it fires up, it's a fuel problem, not ignition
Going to do a check on the fuel pump that homer told me about to test if it's running proper. There's fuel getting to the chambers cause when we took the new plug out of chamber 1 to do the timing I checked to see if you could smell fuel on it
How much fuel though? Bear in mind that although fuel evaporates quickly, the smell may not.
I bridged the +B and FP in the diagnostic port to check the pump is working and then turned it over using that method, still no luck !
Is the rotor arm in the dizzy in the correct place?
Yeah te rotor arm is pointing to 1 on the dizzy, we set all that up with Craig (dr_jekyyl) yesterday dude.
Just checked all fuses and everything is ok, done an error code check again and it's still throwing up code 12
