StevenOd Posted July 25, 2013 Share Posted July 25, 2013 Hey everyone, pick up my first supra on Saturday and it was a jap import, I'm just wanting to know is there is any parts different from the uk spec before I start ordering service parts etc. First of all I will be carrying out a major service, oil filter plugs etc and pads and discs all around just don't want to order the wrong parts and want to make sure I've got the right ones. Any help would be great thanks! Link to comment Share on other sites More sharing options...
Josh42 Posted July 25, 2013 Share Posted July 25, 2013 Hi Steven, Welcome to the club. There are quite a few differences between a Jspec TT and a UK. First of all the UK's all have the larger 4 piston front brakes and 2 piston rear brakes, which were an option on the JSpec. The UK runs on a MAF sensor, as opposed to prefacelift Jspec's which run on a MAP sensor. Spark Plugs, oil and fluids should be similar. Link to comment Share on other sites More sharing options...
Josh Posted July 25, 2013 Share Posted July 25, 2013 http://www.mkivsupra.net/vbb/showthread.php?59334-Supra-Guide-and-Model-Differences-Chart That's a guide to the differences between them, but I'm not sure it's what you're looking for. For brake pads and discs, you need to check if they're the larger brakes (commonly called UK Spec brakes) or the smaller (J-spec) ones. Either 4 pot front, 2 pot rear or 2 pot front and 1 pot rear Link to comment Share on other sites More sharing options...
Dnk Posted July 25, 2013 Share Posted July 25, 2013 (edited) Post some close up photos of your calipers through the wheels and we can let you know what you have. Is your car totally stock ? For example does it have an airbox or induction kit, is it running higher boost Edited July 25, 2013 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Guigsy Posted July 25, 2013 Share Posted July 25, 2013 There are a lot of smaller things but I can't remember specifics. Stuff like extra bits in the engine bay, diff coolers and stuff. Extra fuses and ecu etc is different. Different injectors, seats. Bumpers, headlights, bonnet. But as far as servicing items. I think they are the same as long as you get the correct pads Link to comment Share on other sites More sharing options...
Nic Posted July 25, 2013 Share Posted July 25, 2013 (edited) Supra Brake Setups Fluids Spark Plugs Edited July 25, 2013 by Nic (see edit history) Link to comment Share on other sites More sharing options...
Nic Posted July 25, 2013 Share Posted July 25, 2013 (edited) In basic term, a lot of parts are the same on the UK and J-spec Supras and a lot of parts are specific to the particular model/year. Any UK Toyota dealer can supply you with OEM parts for any Supra, be it UK or J-spec. Most service parts such as plugs, fluids, filters, brake parts etc. are common across Supra models. If you are looking for a specific OEM Toyota part, then the best thing to do is give the VIN details of your car to a Toyota dealer and they will be able to look up on their Electronic Parts Catalogue (EPC) for the exact part number you need. Alternatively you could just ask on here and one of us with a copy of the EPC will be able to help with part numbers. If you have a list of parts you need, post it up and we'll be able to give you an idea of what you need and where best to get the part. Edited July 25, 2013 by Nic (see edit history) Link to comment Share on other sites More sharing options...
StevenOd Posted July 25, 2013 Author Share Posted July 25, 2013 Thanks guys, Yeah its totally stock Link to comment Share on other sites More sharing options...
kitch79 Posted July 25, 2013 Share Posted July 25, 2013 Ive used this page for many a month to gather info... http://mkiv.supras.org.nz/specs.htm Link to comment Share on other sites More sharing options...
