New BIGGER brakes
darrenlee1981
They`d be a good upgrade from jspec 2 pots but not really an upgrade from 4 pots, 2 problems with wilwoods is no dust seals and caliper flex (i did read up a few months back) as i was going to change to these so i could use performance friction pads, i spoke with 1 of our racecar guru`s from here and he put me off wilwoods full stop.
Should I upgrade the rears?
Yes if you want to keep the front/rear brake bias balanced then the rear brakes should be matched to the fronts. Just fitting larger brakes on the front will put more of the braking force through the front tyres, this will cause the fronts to lock up before the rears.
If you want to upgrade your brakes, I'd personally go with a set of the standard larger Supra brakes front and rear.
Why upgrade to ds2500?? They are excellent pads but useless after 1-2 hard brakes. Used them before on 6 pot 356mm discs excellent cold bite brilliant pad but useless after few hard brakings. Sayong that i never used yellow stuff aint sure what they are like
I guess depends what type of driving you do
Edited by Gpro (see edit history)
