Vvti tt airbox vs tt airbox are they different?
MattP
  Dnk said:
Doesn't the MAF just bolt to the airbox the same way it does on a UK spec ?
If so i have a complete UK airbox with both the top and bottom air feeds in the for sale section
The UK Spec is a different part number and has a different outlet pipe.
http://img838.imageshack.us/img838/5304/g72l.jpg
  Nic said:
The EPC shows that the actual airbox and lid are the same on the VVTi and non-VVTi, both same part number 17700-46200. The NA airbox is definitely different to the TT.
VVTi
http://img4.imageshack.us/img4/4311/uae1.jpg
non-VVTi
http://img4.imageshack.us/img4/6082/70p9.jpg
Saying that the VVTi and non-VVTi are different on the image, there's an extra bracket on the outlet.
  • 5 years later...
  MattP said:
It doesnt the VVTI has the Maf sensor on a separate tube the UK has it on the box itself
Vice versa. Vvti is moulded onto the airbox, UK has separate pipe
Basically, I've only seen a vvti box not a UK one. However I very much doubt they are compatible.
