MattP Posted July 23, 2013 Share Posted July 23, 2013 Hi guys can somebody clarify for me that the TT vvti airbox is different to a pre facelift TT airbox and if so in what way? Quote Link to comment Share on other sites More sharing options...
SPG Posted July 23, 2013 Share Posted July 23, 2013 The vvti airbox has a build in MAF Sensor, and the non-vvti deos not. Quote Link to comment Share on other sites More sharing options...
MattP Posted July 23, 2013 Author Share Posted July 23, 2013 Damn it Desperate for a VVTI TT airbox then Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 23, 2013 Share Posted July 23, 2013 (edited) Doesn't the MAF just bolt to the airbox the same way it does on a UK spec ? If so i have a complete UK airbox with both the top and bottom air feeds in the for sale section Edited July 23, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted July 23, 2013 Share Posted July 23, 2013 The EPC shows that the actual airbox and lid are the same on the VVTi and non-VVTi, both same part number 17700-46200. The NA airbox is definitely different to the TT. VVTi http://img4.imageshack.us/img4/4311/uae1.jpg non-VVTi http://img4.imageshack.us/img4/6082/70p9.jpg Quote Link to comment Share on other sites More sharing options...
Nic Posted July 23, 2013 Share Posted July 23, 2013 (edited) Doesn't the MAF just bolt to the airbox the same way it does on a UK spec ? If so i have a complete UK airbox with both the top and bottom air feeds in the for sale section The UK Spec is a different part number and has a different outlet pipe. http://img838.imageshack.us/img838/5304/g72l.jpg Edited July 23, 2013 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted July 23, 2013 Share Posted July 23, 2013 The EPC shows that the actual airbox and lid are the same on the VVTi and non-VVTi, both same part number 17700-46200. The NA airbox is definitely different to the TT. VVTi http://img4.imageshack.us/img4/4311/uae1.jpg non-VVTi http://img4.imageshack.us/img4/6082/70p9.jpg Saying that the VVTi and non-VVTi are different on the image, there's an extra bracket on the outlet. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 23, 2013 Share Posted July 23, 2013 The difference is where the MAF attaches to the airbox, this is my UK spec Quote Link to comment Share on other sites More sharing options...
MattP Posted July 23, 2013 Author Share Posted July 23, 2013 Ohhh im confused I need the entire induction sytem from the inlet Quote Link to comment Share on other sites More sharing options...
spikedjack Posted July 23, 2013 Share Posted July 23, 2013 Vvti has the maf tube moulded to airbox, definitely different Quote Link to comment Share on other sites More sharing options...
Harvsta Posted September 19, 2018 Share Posted September 19, 2018 Can I use a vvti airbox/induction kit on a non vvti uk spec engine? Quote Link to comment Share on other sites More sharing options...
MattP Posted September 19, 2018 Author Share Posted September 19, 2018 Can I use a vvti airbox/induction kit on a non vvti uk spec engine? yes just block off the Sensor hole. If your next question is what sensor you should hang yourself. Quote Link to comment Share on other sites More sharing options...
MattP Posted September 19, 2018 Author Share Posted September 19, 2018 Also VVTI is king and all you pre VVTI guys can suck it Quote Link to comment Share on other sites More sharing options...
samdale Posted September 19, 2018 Share Posted September 19, 2018 yes just block off the Sensor hole. If your next question is what sensor you should hang yourself. Are you sure? How does a vvti airbox attach to a UK spec MAF pipe? Quote Link to comment Share on other sites More sharing options...
Harvsta Posted September 19, 2018 Share Posted September 19, 2018 Any pics? Quote Link to comment Share on other sites More sharing options...
MattP Posted September 20, 2018 Author Share Posted September 20, 2018 Are you sure? How does a vvti airbox attach to a UK spec MAF pipe? It doesnt the VVTI has the Maf sensor on a separate tube the UK has it on the box itself Quote Link to comment Share on other sites More sharing options...
samdale Posted September 20, 2018 Share Posted September 20, 2018 It doesnt the VVTI has the Maf sensor on a separate tube the UK has it on the box itself Vice versa. Vvti is moulded onto the airbox, UK has separate pipe Basically, I've only seen a vvti box not a UK one. However I very much doubt they are compatible. Quote Link to comment Share on other sites More sharing options...
MattP Posted September 21, 2018 Author Share Posted September 21, 2018 See now im confused again the UK box DNK posted has it moulded to the Airbox but my VVTI had a little tube separate on the stock box. Quote Link to comment Share on other sites More sharing options...
samdale Posted September 21, 2018 Share Posted September 21, 2018 This is my vvti airbox Quote Link to comment Share on other sites More sharing options...
samdale Posted September 21, 2018 Share Posted September 21, 2018 This is a UK one with the separate MAF pipe Quote Link to comment Share on other sites More sharing options...
