1JZGTE Posted July 22, 2013 Share Posted July 22, 2013 When doing my discs and pads yesterday on the front, I used an F clamp to gently push the pistons in, winding in slowly and also made sure the brake fluid reservoir cap was off. I did one at a time, slowly and only as much as I needed to push them in. Got me thinking - how difficult would that job be / how would you approach it with 4 or even 6 pots! Link to comment Share on other sites More sharing options...
Dnk Posted July 22, 2013 Share Posted July 22, 2013 You use the old pads and lever in all the pistons at the same time Link to comment Share on other sites More sharing options...
1JZGTE Posted July 22, 2013 Author Share Posted July 22, 2013 If I do one at a time, am I doing any damage? In my case, the way the caliper is, I simply can't put the clamp anywhere symmetrical, so I did each side individually...pic below to illustrate as it is difficult to understand in words only: Link to comment Share on other sites More sharing options...
Dnk Posted July 22, 2013 Share Posted July 22, 2013 No your fine doing one at a time Link to comment Share on other sites More sharing options...
1JZGTE Posted July 22, 2013 Author Share Posted July 22, 2013 Thanks for the response So I can just about do an oil + filter and a disc + pad change. Link to comment Share on other sites More sharing options...
scott87 Posted July 22, 2013 Share Posted July 22, 2013 Or grab a cheap piston rewind kit of ebay. That way it does 2 pistons at the same time Link to comment Share on other sites More sharing options...
1JZGTE Posted July 22, 2013 Author Share Posted July 22, 2013 If you mean one of these (below), I have one and it doesn't fit, obstructed by several things including the holes in the caliper assembly, as shown above in my pic. Link to comment Share on other sites More sharing options...
scott87 Posted July 22, 2013 Share Posted July 22, 2013 If you mean one of these (below), I have one and it doesn't fit, obstructed by several things including the holes in the caliper assembly, as shown above in my pic. http://www.toolsinstock.com/admin/images/3940.jpg Yer one of those. I have a slightly different one and place it above the piece of metal you are on about, then use a larger plate that came with the kit to wind the pistons in : ) Link to comment Share on other sites More sharing options...
