Gauge wiring source
berg
Ive installed an oil pressure and oil temperature gauges off my cigarette lighter wiring
I now have an aem wideband and tru boost gauges to wire in
Can anyone help me by telling me a suitable ignition switched live i can run these 2 off?
Will the clock be able to power the 2 of them if so which wire is the switched live?
I cant check with the volt meter as the battery is off and im unable to connect it back on at the moment but would like to put my dash abck together :)
Cheers
Ok ill have a look into that...i used the red and blue wire on the cig lighter plug for 2 of the gauges already.
Will that circuit be fine to run 4 gauges off?
Itrader on its way also mate :-)
