Climate control, out of control
Delboy52
Might be worth checking the Cabin Temperature Sensor (as have had similar symptoms in the past on other cars), located near the Speedo/ Instrument Cluster behind the little grille cut outs in the dash trim panel, might have quite a bit of dust on sensor itself causing it to confuse and over compensate the cabin temp.
Or possibly a heater matrix flap servo/ actuator is playing up?
if not, just wondering if it has a Diagnostic function, like some of the later Toyota's,(don't quote me on it but from memory, lol!) by holding "Auto" & "Recirc" at the same time with the Ignition in "ON" position?, normal output DTC'S I think from memory are 21 & 24 which are usually solar sensors, so ignore them.
or as you say it could be that the climate control unit is knackered.
