Bobbystone Posted August 20, 2005 Share Posted August 20, 2005 Hi all. I had a problem a few months ago where my water pump went and pissed all my coolent away. Car bin off road now for about 2months and ive just had the water pump and cambelt changed so i hoped all would be better. But no....... :thumbdown All new coolent in and iv driven it out of the garage and the temp gauge has rissen to 3/4 and there was a small bubbling sound and a small amount of steam out the coolent pipe above the overflow tank. Also i have no use of the heater system as im just getting cold air. :thumbdown Im really wanting to get this sorted as i cant take not driving the soop anymore so please please please help me to solve this problem or im going to sit and cry for the rest of my lonely little life. Thanks All. Rob Link to comment Share on other sites More sharing options...
Steve Posted August 20, 2005 Share Posted August 20, 2005 Sounds like trapped air in the system, try bleeding it again Have you tried replacing the rad cap. They do start bubbling when they are knackered. Link to comment Share on other sites More sharing options...
Bobbystone Posted August 20, 2005 Author Share Posted August 20, 2005 cheers for the fast responce. how do you bleed the system? could it be or has it got a thermostat? how much coolent do i need in the system? cheers Link to comment Share on other sites More sharing options...
Steve Posted August 20, 2005 Share Posted August 20, 2005 When the car is cold. Remove the rad cap. Fill up to the top. Start car and put the heater on its hottest setting with the fan on full. I then found the easiest way to force the air out is to squeeze the two pipes at the rear off the engine that go to the heater matrix (careful though they will get hot). You should see air come out of the rad. Just keep topping with fluid as needed. After about ten minutes of this you should find the heater gets hot. Replace the rad cap, top up the expansion tank to the required level and enjoy. If you still get the bubbling noise after a drive you may need to replace the rad cap as it is probably knackered. Think the system holds about 9.5 litres of fluid. best to use Toyota Forlife (red stuff) Hope this helps Link to comment Share on other sites More sharing options...
Bobbystone Posted August 20, 2005 Author Share Posted August 20, 2005 cheers steve. im going to drive the car back to mine and park up till monday when i get another 5litres of 4life as ive only put 5litres in could that be the problem??? ill update monday to see what iv sorted. Link to comment Share on other sites More sharing options...
Steve Posted August 20, 2005 Share Posted August 20, 2005 Yes mate as i said it holds approx 9.5 litres when empty i think. So you will probably need more. Keep us posted Link to comment Share on other sites More sharing options...
Bobbystone Posted August 22, 2005 Author Share Posted August 22, 2005 all seems ok now. managed to get heater working after getting all the air out and the temp has stabalized to a nice healthy level. just need some more coolent in the system to top it off. cheers for the guidence steve(top bloke) Link to comment Share on other sites More sharing options...
Nic Posted August 22, 2005 Share Posted August 22, 2005 Bobby, did you change the rad cap when you had the new pump fitted? If you have boiled over before, then this will probably have knackered the rad cap too. If the rad cap is not holding the pressure you will see temps rise as you describe. Link to comment Share on other sites More sharing options...
Bobbystone Posted August 22, 2005 Author Share Posted August 22, 2005 i do need a new rad cap now ithink so ill get a new TRD one as ive heard there the one too get. Link to comment Share on other sites More sharing options...
Steve Posted August 22, 2005 Share Posted August 22, 2005 all seems ok now. managed to get heater working after getting all the air out and the temp has stabalized to a nice healthy level. just need some more coolent in the system to top it off. cheers for the guidence steve(top bloke) No worries mate glad to help. Speak to Nic for the rad cap he can get them quite cheap. Glad its all sorted. Link to comment Share on other sites More sharing options...
