couple of problems, advice please
girth45
Hi , got the car running again this evening after doing a few jobs, replaced the fuel filter and now have a leak from the in side fitting, can't get the fitting tight enough, still keeps dripping, working down the threads, removed and refitted a few times still leaking, has anyone else had this problem and if so how did you fix it.
Also replaced leaking a/c condenser had it gassed again and now have a leak where two pipes join, I guess there is a o ring seal, so I need some part numbers, can anyone help.
Thanks.
Thanks.
I had the same issue with my SC300 and it sucked. I found that I over torqued the crush washer and had to get a new one. Once I did that all was well. Someone on SF told me hand tight, but I just went with what was in the manual for tightening. It seemed a little tighter than hand tight.
Be sure to check for fuel smell after you get home from a cruse. Mine leaked after boost due to increased pressure. I also changed my fuel filter which I think may have been clogged with something. After that and the new crush washer my fuel leak went away.
yes thats correct, only way to stop the leak was to use ptfe tape on threads, not happy with this repair but it has stopped leaking, maybe a new fuel line needed.
