Low boost NA-T Build
bluedrag
yea Noz i just have the ge ecu currently i was reading up on a couple of sites and they said they could handle about 8psi of boost before they started giving issues but i guess that was wrong... ill look into a greedy emanage blue then and see how i go
cheers guys
  • Replies 56
cheers guys
I will be using an Emanage on mine having read that they work pretty well on MAP based NA-T's, although not meant to be as good on the MAF based NA-T's in the U.S etc. Hope you get it sorted soon and keep us updated!
You can input basic settings to run the car after youve installed it.
Theres no real base map as such
^^^^^ yeah that! You just input your engine code and it pritty much dose the rest of the work for you by inputting the correct sensors itself, then you start her up and off you go! But remember not to come into boost untill you have had it mapped! Other then that its perfectly safe as it runs just off the stock settings :)
ok this may seem like a stupid question but i was thinking today the main reason they dont handle boost on the factory ecu is because the map sensor doesnt operate at anything more than atmospheric pressure right, so what if you changed the map sensor alone to say a 2.5bar unit and then tried to run it? my brother who is a mechanic has a $1000 afm unit for diagnostics etc on toyotas and it is reading at 15-16 fuel ratio when the turbo is spooling so in theory under boost it should be alright to a point???
purely a question map sensor as a cheap option to try first???
