Guest micke547 Posted July 18, 2013 Share Posted July 18, 2013 supra TT 6 spd -94 J-spec problem: odometer,ABS-light,airbag-light,oil-pressure and "the yellow engine-light" dont light up, the red exclamationmark, door open, slip-cont,and all the gauges and their lights are working fine. i have checked the fuses both inside the car(5,6,10,13,14,15) and in the enginebay and they all appear to be just fine. i dont know if this have something to do with the problem, but about a week before the warninglights stopped working, the idle on the car changed. at first it did always idle at about 1600 when cold, and then drop to about 7-800 when warm. Now, it idles at 1100 when cold for about 10 sec, then drop to 580-600, when warm it starts at 800,drops to 500 and rises to 580. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 18, 2013 Share Posted July 18, 2013 The warning light problem is a common issue caused by dry solder on the warning light PCB. Try doing a diagnostic check to see if there are any stored error codes, see this thread http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes&highlight=diagnostic Quote Link to comment Share on other sites More sharing options...
Guest micke547 Posted July 18, 2013 Share Posted July 18, 2013 (edited) Thanks for the answer, went out to the car, disassembled the right side of the top dash to find this I will try to re-solder it, and hope that it fix the problem Edited July 18, 2013 by micke547 (see edit history) Quote Link to comment Share on other sites More sharing options...
