drift_bear Posted July 17, 2013 Share Posted July 17, 2013 Just been to my local Toyota to get ATF for a full system flush (10 litres worth) and it was dextron III I got, according to the FAQ section on here it says Toyota type IV is recommended. Question is this - is the dextron III the same? My car is a 94 JDM TT Link to comment Share on other sites More sharing options...
Rajinder Posted July 17, 2013 Share Posted July 17, 2013 At Toyota Dextron III and type IV are two different fluids. The ATF type IV is a bit more expensive, I paid £52.00 with 15% discount for 5 litres. Wheather you can use Dextron III instead of IV I am not sure. Since I do track days and did not want to take any risks, so stuck with IV. Link to comment Share on other sites More sharing options...
drift_bear Posted July 17, 2013 Author Share Posted July 17, 2013 At Toyota Dextron III and type IV are two different fluids. The ATF type IV is a bit more expensive, I paid £52.00 with 15% discount for 5 litres. Wheather you can use Dextron III instead of IV I am not sure. Since I do track days and did not want to take any risks, so stuck with IV. When I phoned and told them I was needing ATF fluid then that's what they said they had for it, hopefully one of the traders can shed some light on it! Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 17, 2013 Share Posted July 17, 2013 If it were my car I would happily put Dexron III in it, but if you are a worrier get Toyota IV fluid. Link to comment Share on other sites More sharing options...
drift_bear Posted July 17, 2013 Author Share Posted July 17, 2013 If it were my car I would happily put Dexron III in it, but if you are a worrier get Toyota IV fluid. I asked for type IV and they said they use dextron III, was just wanting to make sure. Thanks chris Link to comment Share on other sites More sharing options...
Rajinder Posted July 17, 2013 Share Posted July 17, 2013 This should help.tc003_99[1].pdf Link to comment Share on other sites More sharing options...
drift_bear Posted July 17, 2013 Author Share Posted July 17, 2013 This should help. Thanks but that's just confused me lol, if chris says it will be fine then it should be mate Link to comment Share on other sites More sharing options...
dude Posted July 17, 2013 Share Posted July 17, 2013 Dexron 111 for me as well;) Link to comment Share on other sites More sharing options...
drift_bear Posted July 17, 2013 Author Share Posted July 17, 2013 Dexron 111 for me as well;) that will be the end of that question then Link to comment Share on other sites More sharing options...
Swampy442 Posted July 17, 2013 Share Posted July 17, 2013 Type IV and dex 3 ARE NOT COMPATIBLE. So if you have one and you want to change to the other you need a good flush. Also Ive always used dex 3 and had heat from some people, glad to see Ive been vindicated Link to comment Share on other sites More sharing options...
drift_bear Posted July 17, 2013 Author Share Posted July 17, 2013 Type IV and dex 3 ARE NOT COMPATIBLE. So if you have one and you want to change to the other you need a good flush. Also Ive always used dex 3 and had heat from some people, glad to see Ive been vindicated It's getting a full system flush Craig, that's why I got the last 10 litres Toyota had lol Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 17, 2013 Share Posted July 17, 2013 Hmm, I have always been led to believe that like brake fluids, ignoring the too similarly named DOT 5 silicon fluid, auto transmission and power steering fluids ARE backwards compatible, albeit with lesser wear, temperature ceiling or longevity levels. It's a grey area, and as I said, I'd be happy to use Dexron III in a BMW or Toyota Getrag box, but if you are a worrier, use the manufacturer's recommended stuff. I do NOT believe mixing Dexron III and Toyota IV fluid will do anything terrible inside the `box. Link to comment Share on other sites More sharing options...
Richie1985 Posted July 17, 2013 Share Posted July 17, 2013 I got Type IV from Toyota when I told them it was a A340E box as they were unsure as the system listed 2 types for the Supra. Got 5 litres for £36.52 Link to comment Share on other sites More sharing options...
garethr Posted July 18, 2013 Share Posted July 18, 2013 What is marked on the dipstick? Early Soarers say Dexron, later ones say T-IV (although I doubt if the internals changed ) . Don't know about Supras... Link to comment Share on other sites More sharing options...
ubersonic Posted July 18, 2013 Share Posted July 18, 2013 What is marked on the dipstick? Early Soarers say Dexron, later ones say T-IV (although I doubt if the internals changed ) . Don't know about Supras... The MKiii Supra with factory 1JZ-GTE & A342E used Dex 3 too. @OP if your doing a full ATF change are you planning on changing the ATF filter too? may be worth it if the cars covered many miles/years /shrug Link to comment Share on other sites More sharing options...
oilman Posted July 18, 2013 Share Posted July 18, 2013 The Dexron III is likely to be fine, but the T-IV fluid is a higher spec one that will cope with higher temperatures. Cheers Tim Link to comment Share on other sites More sharing options...
