ashbuster Posted July 13, 2013 Share Posted July 13, 2013 i was just wondering if its alright to pull the engine with the tt downpipe still attached does it cause any issues or is it not in the way. i cant see it being an issue but its a real pain in the ass to do it while its on the car Link to comment Share on other sites More sharing options...
ashbuster Posted July 14, 2013 Author Share Posted July 14, 2013 so no one Link to comment Share on other sites More sharing options...
Benjy Posted July 14, 2013 Share Posted July 14, 2013 The back of the engine/gearbox needs to be pointing at the floor at about 45 degrees. So as long as it won't hinder that, or catch on anything on the way out, you should get away with it. Link to comment Share on other sites More sharing options...
ashbuster Posted July 14, 2013 Author Share Posted July 14, 2013 thought so bud. do you guys get someone to lye down underneath the car and pull down on the box as its coming out to make sure it doesnt hit? and tie the front bracket shorter so it lifts the front slightly first to get the angle? Link to comment Share on other sites More sharing options...
Benjy Posted July 14, 2013 Share Posted July 14, 2013 I just make sure the car's high enough so that the back of the box clears the floor, hook it up so that the majority of the lift is at the front of the engine, drop the jack that supporting the box and lift away mate Link to comment Share on other sites More sharing options...
ashbuster Posted July 14, 2013 Author Share Posted July 14, 2013 thanks bud Link to comment Share on other sites More sharing options...
dude Posted July 14, 2013 Share Posted July 14, 2013 If you jack the back of the car up it makes life easier;) Link to comment Share on other sites More sharing options...
ashbuster Posted July 14, 2013 Author Share Posted July 14, 2013 hi dude jack the rear and have the front on axle stands? or lower the front when you jack the rear ? Link to comment Share on other sites More sharing options...
dude Posted July 14, 2013 Share Posted July 14, 2013 with the rear up the angle is less extreme that you need to get the engine/trans at, you also need a crane with pretty long reach. As long as you have everything undone theres prob not too much reason to have the front up as well, we always do it on a ramp but thats a luxury. Link to comment Share on other sites More sharing options...
ashbuster Posted July 14, 2013 Author Share Posted July 14, 2013 ahh yes i see this is the crane i have dude http://www.sgs-engineering.com/garage-equipment/engine-cranes/ec2000-2-ton-folding-engine-crane Link to comment Share on other sites More sharing options...
dude Posted July 14, 2013 Share Posted July 14, 2013 The load leveller would be handy in this case, problem is the engine and trans are pretty heavy and with the crane on full reach it will struggle. Link to comment Share on other sites More sharing options...
ashbuster Posted July 14, 2013 Author Share Posted July 14, 2013 is this what i want dude? http://www.ebay.co.uk/itm/1500LB-750KG-Heavy-Duty-Engine-Crane-Hoist-Lift-Leveller-Chain-Load-Garage-New-/261142698190?pt=UK_Lifting_Moving_Equipment&hash=item3ccd5158ce Link to comment Share on other sites More sharing options...
ashbuster Posted July 15, 2013 Author Share Posted July 15, 2013 ordered that load leveler dude this is how its looking crank pulley bolt loosened rad drained and removed/ also the fan power steering removed charcoal canister removed fueling detached and blocked off exhaust off up to the downpipe earths and loom disconnected from the ecu and is pulled up, now sitting on the engine alternator cable removed and fusebox all detached aircon disconnected just leaves draining of the engine and box drive shaft needs removing support braces engine mount shifter which im struggling with then should be ready Link to comment Share on other sites More sharing options...
marc_p Posted July 15, 2013 Share Posted July 15, 2013 ordered that load leveler dude this is how its looking [ATTACH=CONFIG]172411[/ATTACH] crank pulley bolt loosened rad drained and removed/ also the fan power steering removed charcoal canister removed fueling detached and blocked off exhaust off up to the downpipe earths and loom disconnected from the ecu and is pulled up, now sitting on the engine alternator cable removed and fusebox all detached aircon disconnected just leaves draining of the engine and box drive shaft needs removing support braces engine mount shifter which im struggling with then should be ready There is also vac lines that are partially attached to the bulkhead and the water feed that goes to the heater matrix. Link to comment Share on other sites More sharing options...
ashbuster Posted July 15, 2013 Author Share Posted July 15, 2013 yeah bud done i forgot to mention. also removed the little earth on the back and the connecter that goes down by the left of the subframe the autoshifter is whats giving me a head ache lol seems the top is hard to get to, everything is attached i cant get it all off without removing the shifter nob but i cant see how to disconnect the wire and even then its a maze or crap under it Link to comment Share on other sites More sharing options...
Stevo Posted July 15, 2013 Share Posted July 15, 2013 Ash, can you PM me details of how you blocked off the fueling please? Link to comment Share on other sites More sharing options...
ashbuster Posted July 15, 2013 Author Share Posted July 15, 2013 yes bud pm on the way Link to comment Share on other sites More sharing options...
ashbuster Posted July 15, 2013 Author Share Posted July 15, 2013 from the looks of things i dont have to mess with the top part, i can just disconnect the shifter from under the car can anyone confirm this? Link to comment Share on other sites More sharing options...
ashbuster Posted July 18, 2013 Author Share Posted July 18, 2013 been busy guys so sorry to the people waiting for a couple of parts i needed to send, i can arrange this now im free ive been busy helping others and inbetween i managed to get the heart out that load leveler is a life saver Link to comment Share on other sites More sharing options...
markssupra Posted July 19, 2013 Share Posted July 19, 2013 from the looks of things i dont have to mess with the top part, i can just disconnect the shifter from under the car can anyone confirm this? DOH! Too late. Yes, just pull out the P clip from the pin on the shifter linkage. No need to undo the nut otherwise the linkage will need adjusting. Link to comment Share on other sites More sharing options...
ashbuster Posted July 19, 2013 Author Share Posted July 19, 2013 oops too late lol i undone the nut Link to comment Share on other sites More sharing options...
David P Posted July 19, 2013 Share Posted July 19, 2013 Pull P pin on the gear selector adjusting mount and then disconnect the loom at the plugs and mounts, 4 nuts on prop and disconnect the fluid lines to cooler. Link to comment Share on other sites More sharing options...
David P Posted July 19, 2013 Share Posted July 19, 2013 (edited) oops too late lol i undone the nut Not a problem during reassembly push the gear knob/selector all the way forwards into P and pull the selector on transmission all the way backwards into P, then nip it up. Edited July 19, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
ashbuster Posted July 19, 2013 Author Share Posted July 19, 2013 Not a problem during reassembly push the lever forwards into P then pull the selector on transmission back into P, then nip it up. thanks bud Link to comment Share on other sites More sharing options...
