supra_ufo Posted July 13, 2013 Share Posted July 13, 2013 (edited) I inherited some preface lifts to refurb from a member on here..They were already separated and all the bits were taken off which was very helpful however I am unsure where this metal piece fits, there ready to go back in the oven. I am sure its part of the side light but how does it go on? does anyone have any pictures of theirs? I have done a search but cant see pictures referencing where this goes... thanks Edited July 13, 2013 by supra_ufo (see edit history) Link to comment Share on other sites More sharing options...
supra_ufo Posted July 13, 2013 Author Share Posted July 13, 2013 another pic, where does it go lads? I want to cook it tonight! :-) Link to comment Share on other sites More sharing options...
listy Posted July 13, 2013 Share Posted July 13, 2013 I only just took a pre facelift apart for my intake, I *think* it goes under the sidelight, but I'm not 100%, in fact, I'm probably wrong. Link to comment Share on other sites More sharing options...
supra_ufo Posted July 13, 2013 Author Share Posted July 13, 2013 I only just took a pre facelift apart for my intake, I *think* it goes under the sidelight, but I'm not 100%, in fact, I'm probably wrong. I have tried various combinations do you know if it goes on the inner plastic (the part that people spray?) or the light case itself? Link to comment Share on other sites More sharing options...
listy Posted July 13, 2013 Share Posted July 13, 2013 I honestly can't remember mate. I know exactly where the bit in the picture is in my garage too As it only has one bolt/screw hole, I'm pretty sure, once you find where it goes, it's pretty obvious. Sorry I can't be any more help. Link to comment Share on other sites More sharing options...
Stevo Posted July 13, 2013 Share Posted July 13, 2013 If you flip the metal part over 90 deg in the direction of the purple arrow on the attached pic, you should see that each of the metal tabs line up with a small hole. Put the tabs through the hole then bend them back (behind the lens insert) to hold the piece in position Link to comment Share on other sites More sharing options...
Bossco Posted July 13, 2013 Share Posted July 13, 2013 Im sure they would look great in carbon the inside of the light I mean.....not just the silver plate. Link to comment Share on other sites More sharing options...
supra_ufo Posted July 13, 2013 Author Share Posted July 13, 2013 If you flip the metal part over 90 deg in the direction of the purple arrow on the attached pic, you should see that each of the metal tabs line up with a small hole. Put the tabs through the hole then bend them back (behind the lens insert) to hold the piece in position [ATTACH=CONFIG]172344[/ATTACH] I saw those tabs however the screw hole did not line up to the other end (the screws that screw down the side light reflector thing), tried both of them incase I had the sides wrong. Ill have another go and post some pictures of the other side. Link to comment Share on other sites More sharing options...
aaronssupra Posted July 13, 2013 Share Posted July 13, 2013 your welcome to call and compare with my lights if your still stuck mate. im in wakefield Link to comment Share on other sites More sharing options...
supra_ufo Posted July 13, 2013 Author Share Posted July 13, 2013 Just a picture will do if anyone has separated there lights :-) Are yours separated Aaron? Link to comment Share on other sites More sharing options...
aaronssupra Posted July 13, 2013 Share Posted July 13, 2013 no mate there not separated, have got some spare ones here though if you need to take a look Link to comment Share on other sites More sharing options...
supra_ufo Posted July 14, 2013 Author Share Posted July 14, 2013 Still no wiser :-( Link to comment Share on other sites More sharing options...
Supra Gaz Posted July 14, 2013 Share Posted July 14, 2013 Still no wiser :-( You see the slim 'slit' on the plastic edge to the left of the sidelight in this picture, thats where the larger tab goes, them the two smaller ones go in the two small slits, the one between the ridge . In a facelift these cover a hole in the headlight. If you don't colour co-ordinate the panel and put it in you will have three holes in your headlight bezel. I would of done this on photoshop and numbered the points and holes but I'm on my pokey iPhone. Link to comment Share on other sites More sharing options...
SupraD06 Posted July 14, 2013 Share Posted July 14, 2013 (edited) Hope this helps?. By the looks of it that folded up corner goes under the side light bulb. Edited July 14, 2013 by SupraD06 (see edit history) Link to comment Share on other sites More sharing options...
Supra Gaz Posted July 14, 2013 Share Posted July 14, 2013 Hope this helps? By the looks of it that folded up corner goes under the side light bulb. http://www.clearcorners.com/products/toyota/a8/h_lamp2/led_park1.jpg This. Same as a facelift. Link to comment Share on other sites More sharing options...
broomie Posted July 14, 2013 Share Posted July 14, 2013 you lot are hard work! lol, hope this helps! Link to comment Share on other sites More sharing options...
supra_ufo Posted July 15, 2013 Author Share Posted July 15, 2013 ahhhhh So in this pic its been sprayed black? Thank you guys! Link to comment Share on other sites More sharing options...
broomie Posted July 15, 2013 Share Posted July 15, 2013 ahhhhh So in this pic its been sprayed black? Thank you guys! http://i305.photobucket.com/albums/nn205/2jzsupra/Leftheadlightphoto.jpg yep Link to comment Share on other sites More sharing options...
Supra Gaz Posted July 15, 2013 Share Posted July 15, 2013 you lot are hard work! lol, hope this helps! Cheers, I was just logging on to do this. Link to comment Share on other sites More sharing options...
