Aerotop Dave Posted August 20, 2005 Share Posted August 20, 2005 How does the back seat come out? What do I need to undo and where are the screws/bolts located? Many thanks, Dave. Quote Link to comment Share on other sites More sharing options...
D3xt3r Posted August 20, 2005 Share Posted August 20, 2005 The underside is just clipped just lift it up and put it out. Then you can see two 10mm bolts left and right. Open those. Then drop down the back thing and after you lift the carpet there you will see two 10mm bolts again. After you open them and removed the little bolts that hold the carpet you can take the backrest out. Quote Link to comment Share on other sites More sharing options...
Aerotop Dave Posted August 20, 2005 Author Share Posted August 20, 2005 Okay, going to try now. Quote Link to comment Share on other sites More sharing options...
Aerotop Dave Posted August 21, 2005 Author Share Posted August 21, 2005 Thanks for the help - worked fine, only needed to get the seat bit out as it happened. Blimey, just a straight clip-in bit. Not like Toyota's usual belt-and-braces approach at all! Quote Link to comment Share on other sites More sharing options...
