mafia996630 Posted July 10, 2013 Share Posted July 10, 2013 Hey all, See video here of noise: http://tinypic.com/player.php?v=nohuo9&s=5 Can anyone tell me where this is coming from ? I haven't really driven my supra in a few weeks but have not heard this noise before. Thank you. Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted July 10, 2013 Share Posted July 10, 2013 I had mine go and it didn't sound like that. I didn't get a sound...if it's gone you will have issues with power steering cutting out probably. Use tip ex and run a line from the inner part of the pulley to the outer edge. Run the engine and check to see if the line has moved out of place Quote Link to comment Share on other sites More sharing options...
mafia996630 Posted July 10, 2013 Author Share Posted July 10, 2013 I had mine go and it didn't sound like that. I didn't get a sound...if it's gone you will have issues with power steering cutting out probably. Use tip ex and run a line from the inner part of the pulley to the outer edge. Run the engine and check to see if the line has moved out of place I haven't had any issues with my power steering. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 10, 2013 Share Posted July 10, 2013 Do the tippex test on the crank pulley and to help narrow down the noise take the aux belt off and then run the engine Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted July 10, 2013 Share Posted July 10, 2013 The thread I posted about it. http://www.mkivsupra.net/vbb/showthread.php?286491-Power-Steering-Pump-problem-Crank-pulley-problem/page2&highlight=crank+pulley Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 10, 2013 Share Posted July 10, 2013 I couldnt hear anything, apart from a really quiet engine? Could be the aux belt pulley. Quote Link to comment Share on other sites More sharing options...
mafia996630 Posted July 10, 2013 Author Share Posted July 10, 2013 (edited) I think I've done the tipex test. http://imgur.com/Sp4OZTZ,Wufeme7 Did I do it correctly ? Also if I have it doesn't look like the lined has moved. Also I can't hear the noise anymore when I went to do test : s. Edited July 10, 2013 by mafia996630 (see edit history) Quote Link to comment Share on other sites More sharing options...
ashbuster Posted July 10, 2013 Share Posted July 10, 2013 tipex test was done right bud Quote Link to comment Share on other sites More sharing options...
David P Posted July 10, 2013 Share Posted July 10, 2013 Check the viscous fan centre, maybe it's that rattling when hot? Quote Link to comment Share on other sites More sharing options...
