Mk4Gaz Posted December 5, 2014 Share Posted December 5, 2014 With all that in mind, why don't you just get 3mm universal spacers, that way you can use stock studs, and still get a spigot ring on the original hub. 2mm each side won't make that much difference visually anyway, and will cost less than £10 - as opposed to buying longer studs and all this messing about Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 5, 2014 Share Posted December 5, 2014 (edited) Because if my wheels offset and the uk/eu big brakes, the minium spacer i can have on the car is5mm, to get the wheel free from the brake caliber. Edited December 5, 2014 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 5, 2014 Share Posted December 5, 2014 What wheels do you have, widths/offsets? Quote Link to comment Share on other sites More sharing options...
Nic Posted December 5, 2014 Share Posted December 5, 2014 You have 2 choices, use the 5mm spacers without the spigot or fit 10mm spacers which do include the spigot, if the tyres catch the wheel arches with 10mm spacers then you could get them rolled slightly to give better clearance. The post by Digsy - an experience auto engineer - HERE on your other thread would suggest that it is safe to run without the support of the spigot. Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 5, 2014 Share Posted December 5, 2014 What wheels do you have, widths/offsets? azev 10x18 offset 33 Quote Link to comment Share on other sites More sharing options...
jza800 Posted December 5, 2014 Share Posted December 5, 2014 You have 2 choices, use the 5mm spacers without the spigot or fit 10mm spacers which do include the spigot, if the tyres catch the wheel arches with 10mm spacers then you could get them rolled slightly to give better clearance. The post by Digsy - an experience auto engineer - HERE on your other thread would suggest that it is safe to run without the support of the spigot. yes i can see that now thanks, i am gonna use the 5mm spacer, as the car just have got the fender paintet, so would be very sad to have to rolle the fender now Quote Link to comment Share on other sites More sharing options...
manny Posted December 5, 2014 Share Posted December 5, 2014 I have the same spacers on the front of mine and had some aluminium spigot rings made with only a very slightly bevelled (1mm) inner edge so it would still make contact with the hub. Alternatively you could use these 6mm double centering spacers (got these on the rear of mine and they fit perfectly): http://www.wheelspacers.uk.com/product_info.php?k=Sp&info=p939_ALU Quote Link to comment Share on other sites More sharing options...
Big Mark Posted September 6, 2015 Share Posted September 6, 2015 H&R PartNumber:20656014 Width: 10mm Thread Type: 12x1.5 Center Bore: 60.1 Bolt Pattern: 5/114.3 http://www.hrsprings.com/application/search/results/37/614/2010 http://www.trakplus.com/images/trakguidelines/20656014.jpg A bit of a thread revival I know but...... I'm in need of some 10mm spacers but struggling to find the H&R ones in the UK. Only places I can find part number 20656014 is US and Germany, but I don't speak German, Will these fit the Supra or not? http://www.ebay.co.uk/itm/H-R-SV-20mm-20656014-Toyota-Verso-AR2-Spurverbreiterung-Spurplatten-/200893968294?hash=item2ec636afa6 Quote Link to comment Share on other sites More sharing options...
craig85 Posted September 6, 2015 Share Posted September 6, 2015 Might be worth speaking to Superforma, if they don't have the right size on the shelf they'll make some up for you Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted September 6, 2015 Share Posted September 6, 2015 I've just fitted 10mm hubcentric spacers to mine, and used these: Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=221423399258&alt=web Quote Link to comment Share on other sites More sharing options...
Big Mark Posted September 6, 2015 Share Posted September 6, 2015 I've just fitted 10mm hubcentric spacers to mine, and used these: Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=221423399258&alt=web I'm already watching these. Would work perfectly with my Works wheels. Would just need to get some new longer studs. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted September 6, 2015 Share Posted September 6, 2015 Might be worth speaking to Superforma, if they don't have the right size on the shelf they'll make some up for you On their website now. Looks like I can get something custom made for a good price. Quote Link to comment Share on other sites More sharing options...
garethr Posted September 11, 2015 Share Posted September 11, 2015 (edited) A bit of a thread revival I know but...... I'm in need of some 10mm spacers but struggling to find the H&R ones in the UK. Only places I can find part number 20656014 is US and Germany, but I don't speak German, Will these fit the Supra or not? http://www.ebay.co.uk/itm/H-R-SV-20mm-20656014-Toyota-Verso-AR2-Spurverbreiterung-Spurplatten-/200893968294?hash=item2ec636afa6 Search for H&R spacers that fit the Mk1/2 GS300. Edited September 11, 2015 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
