abtin90 Posted July 10, 2013 Share Posted July 10, 2013 I'm looking to run 10mm spacers on the rear of my supra and was wondering whether hubcentric spacers would be needed or not? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
jim Posted July 10, 2013 Share Posted July 10, 2013 I didn't think you could get 10mm hubcentrics bud, I thought they started at 15mm but could be wrong... Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 10, 2013 Author Share Posted July 10, 2013 Oh my bad though I'm sure id seen a pair on driftworks before in 10mm could be wrong though as I'm not very knowledgable when it comes to anything to do with wheels. Is there anything wrong with running a standard 10mm spacer? Quote Link to comment Share on other sites More sharing options...
Littler Posted July 10, 2013 Share Posted July 10, 2013 Have a word with Lee @ SRD iirc he supplied Steve with 10mm hubcentric spacer and also ARP extended wheel studs, it'll be worth doing it properly Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 10, 2013 Author Share Posted July 10, 2013 Thanks mate I'll drop him a pm and see what he says. Quote Link to comment Share on other sites More sharing options...
Littler Posted July 10, 2013 Share Posted July 10, 2013 For reference here is the post in Steve's thread: http://mkivsupra.net/vbb/showthread.php?264733-The-Wangan-Supra&p=3451939&viewfull=1#post3451939 Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 10, 2013 Share Posted July 10, 2013 (edited) H&R PartNumber:20656014 Width: 10mm Thread Type: 12x1.5 Center Bore: 60.1 Bolt Pattern: 5/114.3 http://www.hrsprings.com/application/search/results/37/614/2010 Edited July 10, 2013 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 10, 2013 Share Posted July 10, 2013 these Guys will probably get you them the cheapest http://www.motorsportworld.co.uk/ Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted July 10, 2013 Share Posted July 10, 2013 What wheels are you using them with? I've got 20mm spacers on the front and had to cut the stock bolts down slightly as they fouled on the wheel Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 10, 2013 Author Share Posted July 10, 2013 For reference here is the post in Steve's thread: http://mkivsupra.net/vbb/showthread.php?264733-The-Wangan-Supra&p=3451939&viewfull=1#post3451939 Thanks mate Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 10, 2013 Author Share Posted July 10, 2013 these Guys will probably get you them the cheapest http://www.motorsportworld.co.uk/ Thanks for the info I'll look into it Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 10, 2013 Author Share Posted July 10, 2013 What wheels are you using them with? I've got 20mm spacers on the front and had to cut the stock bolts down slightly as they fouled on the wheel Not too sure as I wasn't able to identify them. The rears are 3 piece 10j and were on Amans car when Jurgen imported it. Quote Link to comment Share on other sites More sharing options...
garethr Posted July 11, 2013 Share Posted July 11, 2013 What wheels are you using them with? I've got 20mm spacers on the front and had to cut the stock bolts down slightly as they fouled on the wheel10mm spacers will use stock or extended wheel studs. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 11, 2013 Share Posted July 11, 2013 (edited) http://www.hrsprings.com/application/search/results/37/614/2010 http://www.trakplus.com/images/trakguidelines/20656014.jpg If you are going to use spacers definitely use hubcentric ones and make sure they have a built in the spigot as shown in the above example. You'll also probably need a spigot ring to fit between the spigot on the spacer and the wheel. Edited July 11, 2013 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 11, 2013 Share Posted July 11, 2013 If you need hub/Spigot rings to fit the Supra 60.1 bore http://www.part-box.com/products.php?search=60.1&osCsid=ad21093ee4be9936b1ec7fabfef5efc3 Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 11, 2013 Author Share Posted July 11, 2013 If you are going to use spacers definitely use hubcentric ones and make sure they have a built in the spigot as shown in the above example. You'll also probably need a spigot ring to fit between the spigot on the spacer and the wheel. Thanks Nic I'll definitely be going for hubcentric ones, don't want to be cutting corners or taking any kind of risk. Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 11, 2013 Author Share Posted July 11, 2013 If you need hub/Spigot rings to fit the Supra 60.1 bore http://www.part-box.com/products.php?search=60.1&osCsid=ad21093ee4be9936b1ec7fabfef5efc3 Thanks again for the link mate Quote Link to comment Share on other sites More sharing options...
jza800 Posted November 30, 2014 Share Posted November 30, 2014 I am also looking at some spacers to my front Wheels, as i got new brakes and my Wheels hit the brakes, but i only need 5mm spacers, but i cant find them with Hubcentric, so do i need the Hubcentric when i only have 5mm spacers on mine??? Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 30, 2014 Share Posted November 30, 2014 H&R do them http://www.hrsprings.com/application/search/results/20/366/1998/ 28 These are hub-centric flat disc type spacers which require the factory hub to center the wheels. Please measure the vehicle hub to verify sufficient height will remain to center the wheel after spacer installation. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 30, 2014 Share Posted November 30, 2014 They are not hubcentric spacers as such as they don't bolt onto the hub (you will still need longer studs), however they are better than a universal spacer as they will fit over the hub spigot and have a built in spigot for the wheel to sit onto ie. the wheels will be supported by the spigot rather than the wheel studs. http://www.amazon.com/10656014-DRS-TRAK-Wheel-Spacer/dp/B00CZBHHYY 60.1mm is the correct center bore for the Supra hub, you will need to measure the center bore of your wheels (the recessed diameter on the back of the wheels that sits over the spigot), if the center bore is >60.1mm then you will need some spigot rings, these are basically adapter rings that fit into the back of the wheels to reduce the centre bore to 60.1mm. Use aluminium spigot rings rather than plastic, I got mine from this Ebay seller http://stores.ebay.co.uk/spigotringsnutsnboltscentreuk/SPIGOT-RINGS-/_i.html?_fsub=2229351010 Quote Link to comment Share on other sites More sharing options...
jza800 Posted November 30, 2014 Share Posted November 30, 2014 ok, but how do you fit them, because as i can read me too there are knurled bolts with the h&r spacer, so how do i fit them right??? is it just buy longere studs, slide the spacer over the studs, put the Wheel on, and put the bolts on the studs??? Quote Link to comment Share on other sites More sharing options...
Nic Posted November 30, 2014 Share Posted November 30, 2014 ok, but how do you fit them, because as i can read me too there are knurled bolts with the h&r spacer, so how do i fit them right??? I didn't realise they included the wheel studs, if they do you'll need to check if they are compatible with the Supra hub, pic here showing the longer ARP studs to fit the Supra. http://www.titanmotorsports.com/arpwheelstuds1.html is it just buy longere studs, slide the spacer over the studs, put the Wheel on, and put the bolts on the studs??? This is the pic from the advert, the spacer will fit over the standard studs and should be a tight push fit onto the hub spigot. With aftermarket wheels as said you will probably need a set of spigot rings, the rings should be a tight fit into the back of the wheels, the spigot ring in the back of the wheels should then be a tight fit onto the spigot on the spacer. Then the nuts can be tightened to the correct torque setting. Quote Link to comment Share on other sites More sharing options...
jza800 Posted November 30, 2014 Share Posted November 30, 2014 http://www.ebay.co.uk/itm/H-R-10656014-Toyota-Supra-Type-A8-TRAK-Wheel-Spacers-10mm-/111334429920?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item19ec0c94e0 you can see here, that bolts that follows.. so is that the bolts to the Wheel > spacer or the spacer > hub i have alu spigot rings to my Wheels Quote Link to comment Share on other sites More sharing options...
Nic Posted November 30, 2014 Share Posted November 30, 2014 (edited) http://www.ebay.co.uk/itm/H-R-10656014-Toyota-Supra-Type-A8-TRAK-Wheel-Spacers-10mm-/111334429920?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item19ec0c94e0 you can see here, that bolts that follows.. so is that the bolts to the Wheel > spacer or the spacer > hub I think you'll need to ask the supplier what is included in the kit, that has the same part number as the one I posted a link to earlier but is a completely different type of spacer. That photo shows a hubcentric spacer which is bolted to the hub and then the wheel is bolted to the spacer, that is the best kind to get but i thought the minimum width you could get these in is 10mm. Edited November 30, 2014 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 30, 2014 Share Posted November 30, 2014 DRS Series spacers fit between the wheel and hub, and require exchanging the existing wheel studs for longer ones (studs are included). It is hub centric Quote Link to comment Share on other sites More sharing options...
