mark newman Posted July 9, 2013 Share Posted July 9, 2013 what is the full weight of a j spec supra any one . Link to comment Share on other sites More sharing options...
chazuk Posted July 9, 2013 Share Posted July 9, 2013 1,550 kg is the offical figure , which is close my aero came in at 1590kg when it was on the mot rollers Link to comment Share on other sites More sharing options...
Nic Posted July 9, 2013 Share Posted July 9, 2013 Supra 2JZ-GTE Between 1490kg - 1510kg depending on model Supra 2JZ-GE Between 1430kg-1470kg depending on model Link to comment Share on other sites More sharing options...
fastcar Posted July 9, 2013 Share Posted July 9, 2013 Supra 2JZ-GTE Between 1490kg - 1510kg depending on model Supra 2JZ-GE Between 1430kg-1470kg depending on model I take it the RZ Would be the lightest of the 2JZ-GTE? Link to comment Share on other sites More sharing options...
Nic Posted July 9, 2013 Share Posted July 9, 2013 I take it the RZ Would be the lightest of the 2JZ-GTE? The overseas GZ Supras were heavier, but things like gearbox type, diff, seats, wheel size, brakes, etc. will all have an effect on the weight. Link to comment Share on other sites More sharing options...
Rich.2211 Posted July 9, 2013 Share Posted July 9, 2013 Are those figures with fuel and a driver or are they dry weights? Link to comment Share on other sites More sharing options...
Iky Posted July 9, 2013 Share Posted July 9, 2013 Facelifts would be lighter from my experience Last month I replaced one of my front seatbelt mechanisms. The prefacelift one was a hefty solid thing compared to my old one. Also noticed, thinner driveshafts to go with the smaller diff. But then again, they got hit with ABS Link to comment Share on other sites More sharing options...
Suprakeith Posted July 9, 2013 Share Posted July 9, 2013 Supra 2JZ-GTE Between 1490kg - 1510kg depending on model Supra 2JZ-GE Between 1430kg-1470kg depending on model Thats good to know as i always been told that supra weights about 1600kg so as mine doesnt have ABS must be around the 1430 figure then Link to comment Share on other sites More sharing options...
ManwithSupra Posted July 9, 2013 Share Posted July 9, 2013 (edited) I got a set of race scales if anyone wants to be sure... No point weighing mine for this test lol Edited July 9, 2013 by ManwithSupra (see edit history) Link to comment Share on other sites More sharing options...
Nic Posted July 9, 2013 Share Posted July 9, 2013 Are those figures with fuel and a driver or are they dry weights? The figures are curb weights, the measurement of these vary from country to country, in Japan I believe it's measured with all fluids, half a tank of fuel and no driver. Link to comment Share on other sites More sharing options...
Herb Posted July 9, 2013 Share Posted July 9, 2013 (edited) Mine weights without driver and an empty fuel tank 1.372 kg. We actually reseted the weighting system because I couldn't believe it was below the 1400 mark. So really not bad for a Mkiv. I guess mine was the lightest supra available. '93 SZ 5-Speed. So no abs, airbags, sportroof, turbos etc. But it does have a retrofitted active spoiler Well I do have to add that it has quite a lot of mods done to it... So for example my custom exhaust system (header midpipe, etc.) is much lighter than stock. Regards, Herbert PS: compare the power per kg of a full equipped stock UK-Spec to that.... Edited July 9, 2013 by Herb (see edit history) Link to comment Share on other sites More sharing options...
mark newman Posted July 9, 2013 Author Share Posted July 9, 2013 whats that in pounds , just trying to get mine down to some american spec's drag cars, with the same set up as mine. Link to comment Share on other sites More sharing options...
mihai Posted July 9, 2013 Share Posted July 9, 2013 I got a set of race scales if anyone wants to be sure... No point weighing mine for this test lol I am interested Link to comment Share on other sites More sharing options...
Guest balloo Posted July 9, 2013 Share Posted July 9, 2013 this is as confusing as near side and offside kerbs :S Link to comment Share on other sites More sharing options...
DaveR Posted July 10, 2013 Share Posted July 10, 2013 this is as confusing as near side and offside kerbs :S Nearside = near to the kerb; offside = not near to the kerb. Dry / wet weights just vary country-to-country. The only way to be sure would be to weigh your own car. Apparently it's possible to do that at a truck weigh station although of course you wouldn't know exactly how accurate the scales actually are. Link to comment Share on other sites More sharing options...
mattdavies Posted July 10, 2013 Share Posted July 10, 2013 1550kg = 3417.17lb Whats your target in Pounds ? Link to comment Share on other sites More sharing options...
V8KILR Posted July 13, 2013 Share Posted July 13, 2013 If you go to the bottom of this page: http://mkiv.supras.org.nz/specs.htm there are all the weights by model and option. Link to comment Share on other sites More sharing options...
