fuel line size
Hartmann
have a question about the fuel line size ? how far will a An8 feed line split to 2x an6 to the rail and a An6 return take me ? .. bourght JamieP old hypertune and thinks it is dual AN6 on the rail .. and that was good for 1000rwhp+
Thanks tobias
Tobias, what pump are you running?
For 800 bhp approx, which was my original goal, as Mark says I spoke with Hodge and he recommended -8an main splitting to twin -6an. I was going to retain the stock return unless pressure became an issue, which I doubt it will.
I bought a single Walbro 450 pump, which should have flowed enough. However, as experienced by Jamiep I was concerned at peak flow if fuel temps would become a problem on a single pump setup.
This would probably be negated with the twin Bosch setup, as most seem to do, with the staggered control. Not sure what your setup will be.
