JayJay1374 Posted July 7, 2013 Share Posted July 7, 2013 Basically looking to change the clutch and fly wheel. I bought the car from a dealer. Got it home and the clutch went. So hoping to get him to sort it or me buy the clutch him the fly wheel. And him fit it. The cars back there now getting the box removed on Monday to investigate. Found this fly wheel http://item.mobileweb.ebay.co.uk/viewitem?itemId=151002598709&index=5&nav=WATCHING&nid=50920974551 Thoughts? But can't seem to find a decent clutch which isn't too pricey (£400ish) All parts are for a 6 speed manual TT cheers JJ Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 7, 2013 Share Posted July 7, 2013 Ah not good mate! I know nowt about clutches & flywheels tbh, but maybe try jurgen as hes the most local trader he may have one laying in storage Quote Link to comment Share on other sites More sharing options...
Justin Bieber Posted July 7, 2013 Share Posted July 7, 2013 Why not OEM Toyota? Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 7, 2013 Author Share Posted July 7, 2013 I thought oem was dual mass? The cars got a BPU so it would be silly not to upgrade the clutch atleast. Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 7, 2013 Author Share Posted July 7, 2013 Ah not good mate! I know nowt about clutches & flywheels tbh, but maybe try jurgen as hes the most local trader he may have one laying in storage It's a nightmare mate. Absolutely wounded. Just got it home. Went to lift the clutch. Nothing at all. Managed to nurse it a couple miles downhill to brass side prison so this could happen Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 7, 2013 Share Posted July 7, 2013 Such a shitter mate, did it drive ok on the way home? Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 7, 2013 Author Share Posted July 7, 2013 Yeah mate. Drove perfect on and off boost. Then about a mile from home you could change down let the clutch out then 5 seconds later it would bite. Then turned it off. Back on and no clutch. Quote Link to comment Share on other sites More sharing options...
Abz Posted July 7, 2013 Share Posted July 7, 2013 (edited) I changed my clutch & flywheel a couple of weeks ago, went stock for both items. BPU is fine for a stock clutch, if you are looking to go single turbo then ideally you'd need to consider an updated clutch. With regards to the flywheel, the stock one is a dual mass flywheel so ideally you want a dual mass rather than a solid one. Edited July 7, 2013 by Abz (see edit history) Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 10, 2013 Author Share Posted July 10, 2013 UPDATE: the garage have took the box off to find this: A triple plate clutch and single mass flywheel. They say they are gonna clean the clutch and replace the release bearing and rebleed the pedal and hopefully that should sort it. The clutch and flywheel are in really good condition. Any theory's of why when lifting the pedal I didn't have any drive? Although the pedal did feel really light? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 10, 2013 Share Posted July 10, 2013 The fluid was maybe goosed mate, dampness within the system like when your brakes feel crap after the cars been laid up for a long while its the same type of system Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 10, 2013 Author Share Posted July 10, 2013 might be mate, ive just researched the car mot history through the dvla, it was first used in the uk in 2010, and mot'd with 40,503 miles recorded, the year after it had 41,234, after then being off the road for 2 years it was mot'd last week at 41,298 so its done very little miles in the uk! and its bearly moved in years. hopefully the garage will sort it Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 10, 2013 Share Posted July 10, 2013 might be mate, ive just researched the car mot history through the dvla, it was first used in the uk in 2010, and mot'd with 40,503 miles recorded, the year after it had 41,234, after then being off the road for 2 years it was mot'd last week at 41,298 so its done very little miles in the uk! and its bearly moved in years. hopefully the garage will sort it Could defintley be the culprit then Johnny stale fluid is a easy quick fix Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 10, 2013 Author Share Posted July 10, 2013 Hopefully it's that simple. Can't wait to get out in it! Quote Link to comment Share on other sites More sharing options...
