HKS FCD problems
Guest Benny9
Guest Benny9
Hi All
Hope somebody can help with my on going fcd problem, i'll try to explain as best I can. ( sorry not great with mechanics ).
Before fitting my fcd my mechanic fitted bleed valves on both turbos to get them to boost just over a bar to make sure we were hitting fuel cut. No problems there as both turbos ran sweet, gauge read 1 bar before hitting FC. We then attached the fcd and 1st turbo now will not run more than 0.6, even after adjusting the bleed valve? we removed fcd again and it went back to 1bar? any ideas? thanks in advance.
Guest Benny9
Cheers buddy
My mechanic actually called to say the same thing after a bit of research, he's going to come round tomorrow to check all wiring is good so hopefully will get it sorted. fingers crossed.
