Single oil drain hitting manifold
marc_p
Hi guys,
Sorry, another question:rolleyes:.
I'm fitting my Whifbitz kit but I'm having a problem with the oil drain on the turbo, as you can see in the pic, when the oil drain fitting is bolted up, it hits the manifold, I have loosened the housing and tried rotating it all over the place but its constantly on the manifold, or if I rotate it past the manifold it points at the chassis with not enough room for a fitting to go on it.
Am I doing it wrong or is it something I need to speak to Paul about on Monday?
Ta
Marc
Is the fitting/tube angled on it's mounting flange? Turning the fitting 180 degrees on it's mounting face/bolts migh solve it if so.
Nope, straight tube, flat surface face.
Just bend it a bit ;)
If only it was that easy:D
