Aftermarket coilpacks?
tony tt
Tony I've got 6 spare ones that are all known to be good, I can send you them so you can find the faulty one if you like.
Hodge you are a legend!! I'm not even sure it is coils but its process of elimination I think. It seems like its a coil issue that's starting to rear its head. Car drives great but there's an intermittent loss of power about 5500rpm at wot in 3rd. It doesn't do it all the time though so in thinking its ok for the moment but potentially going to fail in the future. Ill pm you my address Hodge thank you.
I had a similar type of issue in my TT, turned out to be plugs. Once I was at WOT in the higher gears, when the engine was under most load and making the most boost, I develop a stutter/power decrease. A change of plugs cured it :)
Just thought it may be potentially cheaper suggestion if you haven't changed the plugs in a while.
Edit - just noticed yours is an intermittent fault
I read Marty Bondango at SSI was selling coil packs at a great price. He's not an official trader on here so hopefully I'm still allowed to recommend.
*edit
Found an old post on Facebook, £180 + vat for a set. Not sure if they're still available as they're not listed on the website. :thumbs:
Edited by nige-rz (see edit history)
