berg Posted July 5, 2013 Share Posted July 5, 2013 This will probably sound dumb but im not with the car and cannot check myself Can someone tell me why the crankshaft pulley needs to be removed to do the cambelt on an N/A? Is it because there is a cambelt cover behind the pulley? Was going to attempt it sunday as im doing a TT headgasket on my NA-T build but looks like ill need a puller to get the pulley off Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted July 5, 2013 Share Posted July 5, 2013 You can't remove the lower engine cover with the crank pulley still attached to the end of the crank. You can't remove the old cam belt or fit the new one with the lower engine cover still in place. Unfortunately it will definitely need to come off mate. Quote Link to comment Share on other sites More sharing options...
berg Posted July 5, 2013 Author Share Posted July 5, 2013 Ok thanks for confirming mate ill have to get hold of a puller tomorrow then Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted July 5, 2013 Share Posted July 5, 2013 Ok thanks for confirming mate ill have to get hold of a puller tomorrow then Best to do it right mate. It will be easy with the correct tools Quote Link to comment Share on other sites More sharing options...
