Clutch alignment
T2 MSW
Damn I should read threads before I reply !!! I just saw where can I get a clutch tool !!!!
Cheers anyway fella. May get one anyhow as doing it on the gearbox is designed so when your under the car its easy to do the bolts up through the inspection panel. Im doing it on the floor and putting the engine and gearbox in as one :)
You wont get much easier than the Getrag, starngely my Porsche is a pull clutch but the plate and cover are all aligned and bolted to the flywheel before the box goes on.
Like CW says there is only 1 way, so you need to have the engine raised when you put the box on so you can get access to the windows to do the bolts up holding the cover on and get the clutch fork in.
