What Plug is this?
Caesard
There is already a plug in the steering shaft. This one comes from the block and is part of the set of which one plugs into the back of the alternator. I think there are 5 different plugs in all coming from one cable from the engine.
As the loom hiding guru says, I think it's a PAS rack connector, too. From memory the rack has two connectors, that one and a very small one. or is that Skylines.... It's not vital to the thing running, anyway ;)
Your right Chris, but only an auto has 2 connectors, a manual has the above connector. It's for your speed assisted power steering. The faster you go, the stiffer your steering gets, this is just a signal wire from the ECU.
Aha, might explain why my power steering is so stiff, i cant turn it with one hand, even though i have bled the fluid countless times.
My car is an auto, so means i have to hunt for the connector. If my steering rack is from a manual, will it still have 2 connections, eh Hodge, oh loom hiding guru?
No it will only have 1. I'm not a tidally sure what the other connector is for, odviously something to do with the gearbox. If you havnt got the other one (it's a single wire sound plug) don't sweat it, it will still work fine.
