Al Massey Posted July 5, 2013 Share Posted July 5, 2013 Is there any way to tell which diff it is just by looking at it? Ie the code on my car says I have an LSD on my 5 speed NA and I would like to check now I have it off. Cheers Link to comment Share on other sites More sharing options...
T2 MSW Posted July 5, 2013 Share Posted July 5, 2013 Dont think so fella, most are based on the code from the car it comes off. Have to take the cover plate off. Link to comment Share on other sites More sharing options...
Swampy442 Posted July 5, 2013 Share Posted July 5, 2013 No mate, just whip the drain plug out, get a good head torch or similar and have a look inside. Link to comment Share on other sites More sharing options...
Al Massey Posted July 5, 2013 Author Share Posted July 5, 2013 How can you tell from the internals? Cheers for the replies guys Link to comment Share on other sites More sharing options...
Swampy442 Posted July 6, 2013 Share Posted July 6, 2013 I did exactly the same thing last week mate with a car that supposedly had an LSD, if you turn the prop shaft and see anything like the pic below, its an LSD. There is another way involving turing wheels and other wheels turning or not turning lol, I cant remember which. Link to comment Share on other sites More sharing options...
Al Massey Posted July 6, 2013 Author Share Posted July 6, 2013 I did exactly the same thing last week mate with a car that supposedly had an LSD, if you turn the prop shaft and see anything like the pic below, its an LSD. There is another way involving turing wheels and other wheels turning or not turning lol, I cant remember which. http://i76.photobucket.com/albums/j40/Swampy29/null_zps7ecc879c.jpg Might have to split my diff then. If I turn one wheel the other spins in the opposite direction.... Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 7, 2013 Share Posted July 7, 2013 If it were a none OE plate type diff both wheels would turn in the same direction, if the rear was jacked up, and you rotated one wheel, with the gearbox in neutral. With the pretty useless stock torsen LSD, or an open diff, this is not a true test. You need to whip the cover off the diff assembly and look inside, or use an endoscope. - - - Updated - - - If it were a none OE plate type diff both wheels would turn in the same direction, if the rear was jacked up, and you rotated one wheel, with the gearbox in neutral. With the pretty useless stock torsen LSD, or an open diff, this is not a true test. You need to whip the cover off the diff assembly and look inside, or use an endoscope. Link to comment Share on other sites More sharing options...
Slam Posted July 7, 2013 Share Posted July 7, 2013 Dose this answer you questions . I have a n/a auto. Done this on a private road Link to comment Share on other sites More sharing options...
Slam Posted July 7, 2013 Share Posted July 7, 2013 Zooom. In. Its me Link to comment Share on other sites More sharing options...
