Fitting an FPR, change of feed?
marc_p
Hi Guys,
Another question!!
Currently fitting my Aeromotive FPR on a stock fuel rail(I have the Supra fitting kit), but curious to how it fits, am I now blocking off the standard fuel feed with the fuel now being fed through where the stock fuel feed sat?
I have fitted my fuel pulsation dampner removal kit, so is it just a case of the fuel line going straight from the filter, to the FPR and then to the rail fitting where the stock FPR sat?
Or is it a vacuum line that sits on the new fitting and the system goes from the fuel filter, to the FPR, to where it fed as standard ans then just a vacuum line running from the FPR to the fitting where the stock FPR sat?
The FPR is in the return line, so its filter, fuel rail, fpr, then return.
FFS, I think I need a night off from working on the car, cant see the wood for the trees type of thing going on here(I was trying to work out the above at 2am this morning :D).
On another note, does anyone have a picture to show where they routed the piping and mounted the FPR?
Whilst on the subject does anyone know what the thread type/size is of the stock fuel rail feed. I'm trying to find an adapter to fit a hose directly to the fuel rail and delete the pulsation damper whilst I'm at it but I don't want to spend 100 coins on "the bypass kit"
PM Hodge ;)
I've just purchased one off him, so providing it's the same as the TT fuel rail, Hodge will have your answer.
  • 6 months later...
