coza Posted July 4, 2013 Share Posted July 4, 2013 Hi, Just wondering if I was to sell / swap my 5 speed box how much for the 6 speed box and all the other bits I will need ? Cheers Quote Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted July 4, 2013 Share Posted July 4, 2013 budget for around £2.5k Quote Link to comment Share on other sites More sharing options...
Nic Posted July 4, 2013 Share Posted July 4, 2013 (edited) Your current 5spd box is not worth a lot and 6spd gearboxes seem to be getting difficult to find. I'd be tempted to look around for a late model 6spd NA Supra (May 96 onwards), swap the gearboxes over and then sell the NA on. Edited July 4, 2013 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
coza Posted July 4, 2013 Author Share Posted July 4, 2013 What other parts do you need as well as the gear box ? So new clutch ?, fly wheel ? Etc ... Quote Link to comment Share on other sites More sharing options...
thetrashcanman Posted July 4, 2013 Share Posted July 4, 2013 What other parts do you need as well as the gear box ? So new clutch ?, fly wheel ? Etc ... That would be it I believe if you manual, oh also prop and possible diff if you want to, as the N/A diff will mean your changing gear every 10 seconds. Id budget probably 2.5k as well, and I think the 5 speed box on its own is worth maybe £300 Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 4, 2013 Share Posted July 4, 2013 As ypur already 5 speed there is no cutting of tunnel needed and master cylinder and pedals already there. You just need to swap out the box along, clutch, flywheel prop and diff. You'll prob need as mentioned around £2-2.5k plus whatever's needed for a suitable clutch. You'll prob get around £300-400 for the w58 you have now Quote Link to comment Share on other sites More sharing options...
coza Posted July 4, 2013 Author Share Posted July 4, 2013 Okay that would be good then so in the winter that's when il plan to change it Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted July 4, 2013 Share Posted July 4, 2013 Around £2.5k-3k for a decent 6 speed conversion! Quote Link to comment Share on other sites More sharing options...
Josh42 Posted July 4, 2013 Share Posted July 4, 2013 Coza, I've pm'd you Quote Link to comment Share on other sites More sharing options...
coza Posted July 4, 2013 Author Share Posted July 4, 2013 Oh yes lol only just looked , I'm gonna be changing the gearbox sometime in the winter when I have everything in place Quote Link to comment Share on other sites More sharing options...
Abz Posted July 4, 2013 Share Posted July 4, 2013 I'd say you'd be looking at closer to £4k if you include a new clutch, 6 speed box & DMF. Ideally you'll want to make sure the gearbox seals are all good & fresh fluid whilst you are there too. Then you got the cost of labour... Unless you do it yourself. Quote Link to comment Share on other sites More sharing options...
