JayJay1374 Posted July 2, 2013 Share Posted July 2, 2013 what cambelt kits the best to use? generic ebay or genuine toyota or one from partco or similar? what should i be looking for from a kit? also any specialist tools needed to fit it? Link to comment Share on other sites More sharing options...
Swampy442 Posted July 2, 2013 Share Posted July 2, 2013 Just go to Toyota, theyre hardly expensive. Link to comment Share on other sites More sharing options...
Kirk Posted July 2, 2013 Share Posted July 2, 2013 (edited) Gates belt. OEM quality without the OEM tax. http://www.importcarparts.co.uk/parts_info.asp?id=6913&cat=89&sub=1354&sec=1562&var=0&dc=&gen=&searchKey= Edited July 2, 2013 by Kirk (see edit history) Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 3, 2013 Author Share Posted July 3, 2013 price isnt a problem, so what do i need? the belt and tensioner? Link to comment Share on other sites More sharing options...
Iky Posted July 3, 2013 Share Posted July 3, 2013 price isnt a problem, so what do i need? the belt and tensioner? Belt, Idler pulley and tensioner. Water pump & front crank seal as well if you want to service it good n proper Link to comment Share on other sites More sharing options...
Tyson Posted July 3, 2013 Share Posted July 3, 2013 Belt, Idler pulley and tensioner. Water pump & front crank seal as well if you want to service it good n proper Anything else worth replacing for future proofing ? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 3, 2013 Share Posted July 3, 2013 http://www.garagewhifbitz.co.uk/index.php/toyota-12076.html http://www.garagewhifbitz.co.uk/index.php/toyota-12077.html http://www.garagewhifbitz.co.uk/index.php/gates.html All in stock here if needed. Link to comment Share on other sites More sharing options...
Iky Posted July 3, 2013 Share Posted July 3, 2013 Anything else worth replacing for future proofing ? Probably thermostat seen as you'll be draining the coolant and front auxillary belt Link to comment Share on other sites More sharing options...
Iky Posted July 4, 2013 Share Posted July 4, 2013 You'll also need a crank locking tool & pulley remover. if you don't have these, I can lend you for a refundable deposit plus postage. Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 4, 2013 Author Share Posted July 4, 2013 You'll also need a crank locking tool & pulley remover. if you don't have these, I can lend you for a refundable deposit plus postage. i will be in touch when i have all the parts Link to comment Share on other sites More sharing options...
