Pushed front crank seal in to far?
Rich.2211
I think I may have had an over eager moment :blink:
Whilst installing a new front main seal (front crank seal) I have inserted it maybe 0.5mm past flush. The Toyota Service Manual says for it to be installed flush. The worry about installing it too far is that it can block the oil relief hole? One saving grace is that I have the oil pan off at the moment so I can actually look down this hole from the other end (the bottom of the block) and take a picture..
I'm guessing the brown section to the left is the seal covering part of the hole. Does the seal cover a tiny bit of that oil relief hole even when fitted flush? or does it not cover it all?
Long story short, do I need to pull this one out and install a new one, this time without my over eagerness?
Cheers :)
Did you fit a new pump?, reason for changing the seal?
I haven't changed the pump. Had a new front crank seal in the gasket kit so thought I'd change it whilst it everything was accessible.
If I have to pull this one out and replace it with another then it's no huge issue, I just want to confirm that it is actually in too far before I pull it out and fork out for another front crank seal.
Got ya, i`d have been tempted to replace the pump while it was all stripped as you know what a pain it is once the motor is back in the car.
I would have to disagree and say you should get away with that. Ideally a tad further out though. 2 potential issues. In too far the lip of the seal rides on the sides of the wear groove in the crank, and can weep. It can partially block the already marginal oil drain hole that allows oil leaking from end clearance in the pump back down to the sump, and build a pressure behind the seal. This can cause leaks, or in chronic cases, pop the seal almost out against the back of the cam belt cogwheel.
Hi Chris, it was actually myself who called you during the week and enquired about a crank seal. I took your advice and ordered another from Toyota and fitted the new one this evening. The one I fitted this evening sits flush as per the TSRM so should be spot on, touch wood. Thanks for your advice on the phone the other day :thumbs:
I paid €60,- over here :(
Make yourself a tool like I did, you wont regret it:
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=135256&d=1309447373
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=135257&d=1309447453
Will set you back a few pounds (
I made a tool up the second time round, wish I'd of done it properly the first time and saved £20 odd. Live and learn ay!
