supra been standing 18 months, smokey
JayJay1374
Hi all, i went to look at a facelift tt supra the other day, it had been sitting in a paintbooth for 18 months, it started with fresh petrol and a battery but its smoking quite abit, the cars only got 41000k on the clock, so is it smoking because its been sat or could it be dried up seals in the turbos or valve stems?
thanks
jonny
it was a grey smoke but did smell abit like oil, the guys gonna clean up the brakes, the brakes work but the discs are abit rusty, and hes gonna do an oil change too.
well ive left a deposit on the car so hopefully it wont be too bad, dont mind getting my hands dirty :)
it doesnt really smoke on idle but it does smoke when rev'd so it could just be condensation, anyway a deposits been left on the car
If it smokes when revs but not on idle that sounds like the turbo oil seals tbh, if you can take it for a drive, take it over 4000rpm and then lot off, if the oil seals are going you'll get a big plume of smoke as you come off the throttle
whats the spec 6 speed,auto, turbo,
smashed back window ?
i dont get it?
- - - Updated - - -
sounds more like it, big job?
Good to hear youve bought one dude, like some have said condensation probobly i had this issue a few months back after not starting the car over the winter had a panic on etc basically let it burn the fluid off in the exhaust and its fine now (well apart from a little vss blue on start up :()
When are you collecting it?
