ABS & Cruise Control - no indicator lights
Samurai 20V
Hi guys..
Scratching my head here..
Got a car with me that is not lighting up the ABS & Cruise control lights..
I tried the ffg;
1. Swapped all fuses & relays with my car, (my car is working fine).. No luck..
2. Repaired dry solder in the indicator Display unit. ECU light & oil lights working fine, still no ABS light.
3. Swapped display unit & tested in my car, the ABS light & all others working fine...
4. Tested the ABS on the road, no lock up, felt the pulsating in the brake pedal..
Based on this, seems the ABS is working fine, just the light is not working...
Cruise control, when pressing the switch, I hear a click, but no indicator lights up on the dash..
Not sure what to check next?
Any advice will be appreciated..
Thanks...
Edited by Samurai 20V (see edit history)
