All singing & All dancing service
tony1
Evening all. I will be doing an all singing and all dancing service this month as after owning the car now for nearly 5 years and just hit 106,000 miles it's not had much love.
The car is a 94 UK Spec twin turbo auto with a double de-cat exhaust and K&N panel filter. Here is a list of parts I already have or will be getting in the next couple of weeks.
What I'm trying to find out is, while I'm doing all this work is there anything else worth changing/replacing while I'm at it?
Parts iv already got:
Fully Synthetic engine oil (25ltr drum so I can flush the system)
Oil filter(s) & sump plug washer(s)
Fuel filter
Toyota 4Life Red coolant (Again, enough to flush)
Valve stem seal (Inlet) 90913-02088 12 of
Valve stem seal (Exhaust) 90913-02123 12 of
Cam shaft oil seal 90311-40020 2 of
Cam cover bolts 90105-06166 12 of
Cam cover nut 90179-06288 4 of
Cam cover washer 90210-07001 16 of
Cam cover gasket (Inlet) 11213-46020 1 of
Cam cover gasket (Exhaust) 11214-46011 1 of
Iridium plugs
Parts I will be ordering during the week:
Coil pack clip 90980-11246 6 of
Cam breather hose 12263-46010 1 of
Cam breather hose 12264-46010 1 of
Gearbox oil and filter
Cam belt
Thanks for your time and any advise would be much appreciated.
Edited by tony1 (see edit history)
I know that, but he said he hasn't done anything to the car for 5 years, would suggest it's nearly ready for cam belt change,
Don't worry Pixelfill. My neighbour who is doing the work said the same thing. Cam belt is definitley going on the service list.
Cheers dude.
Brake fluid change.
I'd do this too, double check the brake lines, maybe replace with braided lines if you can. Change to 5.1 Dot brake fluid.
Also would check the front cross member if it is a UK Spec, an under seal after checking for rust.
Laser wheel alignment too?
Will do. Cheers Abz
