girth45 Posted June 29, 2013 Share Posted June 29, 2013 Hi can just the bearing be purchased ? Has anybody sourced just the bearing as mine just starting to feel notchy. [ATTACH=CONFIG]171805[/ATTACH Thanks. Link to comment Share on other sites More sharing options...
straightsix Posted June 29, 2013 Share Posted June 29, 2013 I got one from ebay. Can't remember the number for it but it should be on the bearing itself. You can press or hammer the old one out using an old socket as a drift Link to comment Share on other sites More sharing options...
straightsix Posted June 29, 2013 Share Posted June 29, 2013 (edited) Just found this on Supra Forums: "I just had a bearing failure of my 2JZ accessories belt tensioner pulley. For those that are interested, instead of buying the whole pulley from Toyota you can just replace the bearing itself...it presses out and back in dead easy. The bearing No is 6203 (it's the same bearing for the 1UZ tensioner pulley out of interest, although the UZ pulley itself is bigger). A simple how too: 14mm socket or ring with long breaker bar and turn clockwise to release tensioner and flip belt off. You'll be disturbed how much force this requires, hence the long breaker needed. The pulley bolt undoes in the normal fashion, so turn anti-clockwise. Bearing presses out with a 21mm socket (or near enough).... and press the new bearing back in after lubing with a 30mm socket." I got an SKF bearing - cost less than £3.00 including delivery! Edited June 29, 2013 by straightsix (see edit history) Link to comment Share on other sites More sharing options...
girth45 Posted June 29, 2013 Author Share Posted June 29, 2013 Top man, sorted. Link to comment Share on other sites More sharing options...
LOGIE Posted June 29, 2013 Share Posted June 29, 2013 Import car parts do them. cost more than Ebay though CLICK Link to comment Share on other sites More sharing options...
girth45 Posted June 29, 2013 Author Share Posted June 29, 2013 Sorted it, removed bearing size is 40x12x17 as stated 6203. £1.05 +0.60 postage, bargain thanks for help and info. Link to comment Share on other sites More sharing options...
straightsix Posted June 29, 2013 Share Posted June 29, 2013 Nice work fella! Link to comment Share on other sites More sharing options...
Iky Posted June 29, 2013 Share Posted June 29, 2013 Sorted it, removed bearing size is 40x12x17 as stated 6203. £1.05 +0.60 postage, bargain thanks for help and info. Where did you get it from bud? I need two of them. Link to comment Share on other sites More sharing options...
girth45 Posted June 29, 2013 Author Share Posted June 29, 2013 EBay mate, just did a search for 6203 bearing, Link to comment Share on other sites More sharing options...
Iky Posted June 29, 2013 Share Posted June 29, 2013 EBay mate, just did a search for 6203 bearing, Thanks matey. Link to comment Share on other sites More sharing options...
snake Posted June 30, 2013 Share Posted June 30, 2013 auxillary belt tensioner bearing . make sure its a High Temp sealed bearing and not just an ordinary 6203 bearing as it is right behind the rad . i managed to get one from [Quality .Bearings .Online, ]part number 6203LHA-NTN Link to comment Share on other sites More sharing options...
