Valve stem seals - Head Off
simbasupra
I suppose just the usual checks for deterioration on parts, cam bolts, split breather hoses etc. Check dimensions of head and resolve if required (re-shim if neededc). Of course you don't have to do this but it is a good time to check and see if any are out of correct intended specification whilst it is off.
I desperately need to get mine changed. The smoke on startup after a few days of sitting is embarrassing. Also, it's gone through my neighbour's window into the house a couple of times.. Hope they haven't noticed! lol
Are you removing the engine?
If you are taking the head off you have your work cut out on removing the turbos, manifolds, etc, especially if the engine is left in the bay, to do them with the head on is a fairly straight forward and easy job.
All that stuff can easily come off with the head ;)
Learn some thing new everyday, thought you would of had to of taken it off to get the head off, I suppose it's just the stays, brackets, pipes etc that need to come off
I took it all off to remove the head... but I was taking it all off anyway. But yea, just disconnect the pipes, downpipe, etc and the whole lot will come off. Will need some serious strength to lift it off though, need a pair of strong hands to help out anyway.
Seen a few pics of people using a crane and lifting the head this way. Saves hassle as the turbos are a real PITA.
