Suprakeith Posted June 29, 2013 Share Posted June 29, 2013 Hi i changed my spark plugs today on na jspec supra and she not running right are denso 20s the same as ngk BKR7EIX-11 as the densos were in car and fitted the ngks today. Did replace dizzy and arm aswell but have put old ones back on with no luck. Going to put old plugs bk in tomoz morning. Does sound like car is missing Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 29, 2013 Share Posted June 29, 2013 Are all the plug leads on securely? Did you put the HT leads on the cap in the correct positions? Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 29, 2013 Author Share Posted June 29, 2013 Yes all ht leads are on right numbers on dizzy and did push all ht leads in. Am going to have another go sunday. At minute am running old dizzy with old rotor arm and new plugs and sounds the same as when had new dizzy and arm fitted, so do belive it possibly the spark plugs or something else but did check all vaccum hoses and connections and they all fine Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 29, 2013 Share Posted June 29, 2013 (edited) What do you mean when you say not running right ? If you have a missfire you can narrow it down by removing a ht lead 1 at a time off the dizzy cap which will show you which cylinder has a problem NA's have BKR5EIX IK20'S are the equivalent to BKR6EIX which you fit in a stock tt. 7's go in tt's running 1 to 1.3 bar Edited June 29, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 29, 2013 Author Share Posted June 29, 2013 She sounds like she missing and have smell of fuel so dont think one or more plugs arent firing, and will try that one lead off at time idea see what cylinders arent firing. And i had the denso 20s in but i have a non turbo supra so could the new plugs be the wrong type then? The spark plug code is in 1st post Quote Link to comment Share on other sites More sharing options...
Littler Posted June 29, 2013 Share Posted June 29, 2013 Keith think you have fitted the wrong grade plugs in there, there for a BPU supra ideally as Dunk says I have them in mine and running 1.1 bar Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 29, 2013 Author Share Posted June 29, 2013 I think the same adam now been thinking about it, i got the plugs off ebay listed as na spark plugs which is lesson learnt for me. Will re fit the denso plugs and order some proper na sparks plugs next week, just a pain in the bum shall we say Quote Link to comment Share on other sites More sharing options...
marc_p Posted June 29, 2013 Share Posted June 29, 2013 Keith think you have fitted the wrong grade plugs in there, there for a BPU supra ideally as Dunk says I have them in mine and running 1.1 bar You need the 5's in an N/A, 6's in a TT and 7's in a BPU Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 29, 2013 Author Share Posted June 29, 2013 Thanks for that,will refit old plugs and send others back and get some proper new plugs for supra Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 29, 2013 Share Posted June 29, 2013 ...is everyone convinced the plug grade is the issue? Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 29, 2013 Author Share Posted June 29, 2013 Thats what i thinking as made sure all leads were fitted correctly and all vaccum pipes were fine aswell,am open to any other ideas and advice still as will be working on her again sunday Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 29, 2013 Share Posted June 29, 2013 I've no direct experience of the wrong plugs, I only said it as I thought the effect would be more subtle and unlike your problem perhaps not immediately noticeable on the first start up. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 30, 2013 Author Share Posted June 30, 2013 Well bit of update put old spark plugs back in but while doing up manifold broke this it goes into inlet manifold. Any one know what its called or way to bypass it please Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 30, 2013 Share Posted June 30, 2013 Its technical name is a pulsation damper, you cant bypass it as its a vacuum feed for the MAP sensor I believe. Can still get them from Toyota I believe. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 30, 2013 Author Share Posted June 30, 2013 Thanks for that at least know what is called, does anyone have part number for it all please? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 30, 2013 Share Posted June 30, 2013 Here you go 3265 FILTER, GAS, NO.1 90917-11031 Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted June 30, 2013 Author Share Posted June 30, 2013 You are a star bud, thank you very much will be ordering a new one 1st thing monday. Have glued old one back together and refitted it just to get car running just incase need it, hate doing things like that. Quote Link to comment Share on other sites More sharing options...
