How much power can the stock fuel lines flow
Guest KamSupra
Guest KamSupra
My setup as of today is the following. Officially have purchased all the parts.
Bullseye BW S366 with T3 housing
Tubular manifold + 40mm wastegate
3.5" downpipe
2 row ARC intercooler
Walbro 400lph fuel pump
SARD 800cc Injectors
From general reading I have done it looks like people mentioned the stock fuel lines are good for around 500whp / 600bhp. Plus I know a couple people personally running stock fuel lines with even more power. Assuming I have just swapped the Injectors out to SARD 800cc and swapped the fuel pump out to a Walbro 400lph, what kind of power can the stock fuel lines handle safely?
I will be more than happy with 580-600bhp but I'm really just wondering as I think the S366 has a lot of potential.
My original goal was not to make a very quick straight line car anyways, something mild and focus on the handling.
edit: I also may ask this as well, what about the stock cams, what's the limit on these? I do plan to upgrade in the near future.
Edited by KamSupra (see edit history)
In regard to the stock cams, there is no 'limit' to them so to speak, but there is a point, where replacing them will gain some much larger top end figures.
If you want 600bhp on the S366, you'll be fine on the stock cams :)
