Single turbo conversion
leeg
Bellow are my parts list that I have put together so far if there is anything else I am missing please tell.
Car: 2000 built TT6 VVTI with 75k miles
Electric and Fuel System:
Syvecs SP6
Options
1. 1.0 bar - Low boost
2. 1.2 bar
3. 1.4 bar
4. 1.6 bar - High boost
5. Lean cruise/MOT
6. Antilag
7. Anti-theft
8. Valet mode
Toucan Multi Display
AEM Wideband AFR Gauge-
HKS 1000cc injectors, twin entry rail, adjustable fpr and braided return hose to connect to stock return line, twin intake fuel pumps, SRD Fuel Cooler.
Turbo Kit:
HKS T04Z
This kit includes HKS' newest Garrett-based turbo. It is a 63T Trim with a 1.00 A/R exhaust housing and the normal T04 style flange. This kit is capable of about 750rwhp and spools quicker than virtually any other kit on the market for the power it makes.
This kit utilizes the famous HKS GT S/S Exhaust Manifold and HKS GT2 Wastegate, the best on the market.
HKS oil cooler and relocation kit
Greddy 4 core FMIC
Nitrous Express Intercooler Cooler.
Koyo Rad
Spark Plugs NGK R7436-9
1 head gasket
Jun Plenum with flow work done
Custom 4'' Exhaust from downpipe back
Billet Water Pump Pulley - Silver
Billet PS Pump Puley - Silver
TRD New Thermostat
Twin Fan Set up
Bonnet damper kit
New OEM Coil Pack, leads/cord, clips
Built Head:
SRD 264 Cams
ARP Head Stud
Intake kit w\ filter 4"
Drive Train:
V161 Gatrag 6 speed
Gilken Tripple Plate Carbon Clutch Kit
Brakes:
Endless Complete front and rear 'callipers, disks and pads'. 15'' disks front 13'' rear.
Tyres:
Toyo R888 295/30/19
Toyo R888 255/35/19
Bits and pieces:
1) Hose & fittings for header breather to back of car complete PnP – Just need to weld fitting on cam cover----
2)1x 264 Exhaust Cam SRD
3) Battery to boot kit + billet battery tray.
4) Toyota Celica Throttle Cable----
5) Toyota Head Gasket Kit----
6) Cam Belt----
7) Aux Belt----
8) Billet belt tensioner 'cam belt-----
9) Air Filter 4'' PnP Hose 'Blue' and Clamp – Yes it is 4" Pipe?-----
10) FMIC PS Relocation and alloy catch tank - PnP blue hose and clamps----
11) Toyota Idler Wheel for timing belt----
12) Boot Rubbers-----
13) Hose and clamp only - for hard pipe from upper radiator to engine water neck – Special offer ;-)
14) 8 Position Calibration Switch----
15) 4 Bar Mapsensor Kit with plug----
16) 3 Port Boost Solinoid----
17) Bosch Wideband Knock Sensor----
18) EGT Sensor------
19) Supra Loom adaptor----
20) Oil temp sensor-----
21) Oil Pressure Sensor-----
22) NTK Wideband Sensor-----
23) Fuel Pressure Sensor ----
24) Toucan Display -----
25) TRD Engine Mount and Connector ----
26) SRD Twin Fan Kit
27) Greddy Gear Knob
28) New OEM Boot Strut
29) SRD Aux Pulley
30) SRD Fuel Cooler
31) SRD 160amp Alternator
I wouldn't want to own a single done for 3k. I'd rather have a bpu with a new set of turbos. More reliable for one. Along with other reasons (part quality stc).
Sure it's "oh wow single turbo" but its a bit like buying a car cover from halfords and calling it garage :) it will protect the car from the elements. But it's going to blow away eventually :)
