Error code 14
suprasurrey
My 1994 TT auto has been playing up a bit today, engine warning light on and not firing on all cylinders. I`ve just checked for error codes and it is showing code 14, which is to do with the ignition system. I have replaced the coil pack clips this year and all connections to the igniter pack appear to be good. Has anyone experienced a similar problem, if so any pointers would be most welcome:)
Edited by suprasurrey (see edit history)
Thanks Swampy. I`ve checked the coil resistance and all are fine. I`m getting a fair bit of smoke when the warning light comes on now. I can only seem to manage 0.8 bar boost, although I am full BPU and used to see a healthy 1.2 bar before this problem. Any clues people?
  • 2 weeks later...
I thought I should give an update on this problem for future reference. Although the coil pack wiring had no visible damage I decided to replace as much of it as possible, just to rule this out as a cause. I also removed all of the coil packs, cleaned them up and bent the contacts upwards a little. I now have full boost, no error code and no smoke:yahoo:
