OEM bodykit fastenings ( help )
Matt _Aero top_
Mostly screws into plastic inserts which clip into the sill bodywork.
As the years wear on the plastic insert clips break (through going brittle) and the screws just turn the inserts when you are trying to undo them.
They are all Toyota part numbers which you can still buy from Mr.T
http://www.toyodiy.com/parts/p_J_1998_TOYOTA_SUPRA_JZA80-ALPVZ_7503.html
Part numbers are under the heading CLIP, ROCKER PANEL MOULDING
75867-14070.
If i remember the rightly the OEM skirts (Actual OEM) use the same fastenings as the black OEM sill covers/
Hope this helps
75867-14070.
Hope this helps
I love you for posting this! It happened to me this weekend when trying to undo the screws!
Thanks!
